SOURCE: Lexmark P6250 black ink cartridge won t print
Write to Lexmark - you won't get any joy, but their reply might be interesting. I suspect that Lexmark builds a chip into their cartridges preventing it being refilled. When replying to me they did not admit this, but did not deny it, simply stating that their cartridges were designed for single use only. When I said that, apart from the cost, I wanted to minimise my impact on the environment by refilling cartridges, they pointed out their proud association with Planet Ark. I suspect that Planet Ark is happy to be an apologist for corporate vandals, and I seriously question their 'green' credentials. Order your next cartridges from Europe where the printer companies are not allowed to chip their products.
SOURCE: Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
SOURCE: Lexmark all in one 4270 won't print in black
I know your problem. I just put in new cartridges and it will print the test page, but nothing else. Did you get an answer
SOURCE: lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
1. Look at the indicator light on your Lexmark printer.
You'll need to replace ink cartridges when the light flashes or turns red
instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand
name or purchase a generic version that is compatible with your printer. You
can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the
sides of the Lexmark ink cartridges and pull it out. Dispose of the ink
cartridges in a recycle program like the one at Staples or save the cartridges
for refill.
4. Install the new ink cartridges after removing the
protective tabs. Avoid touching the IC chip when installing the new Lexmark ink
cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print
several pages with the new ink cartridges to make sure you installed the ink
cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
