Need to download a manual for my Sony ICD-UX200 Digital voice recorder in English.
You can view/download the manual here.
SOURCE: problem with memory/erasing discrepancy
I did erase all from the device main menue after having copied them to my computer, that cleared the remaining files and recovered part of the memory. Then I did reformat from the same menu and recovered the entire memory! ;)
SOURCE: where can i get an instruction sheet for a sony
Click Sony Support to download user manual copy for ICD-B500
Thanks.
SOURCE: How to turn it off???
Make sure the device has stopped recording or playing by pressing the stop button. Then slide the hold switch to "hold" and the device will turn off in about 6 seconds.
SOURCE: I have just gotten a Sony MP3 IC recorder, but it
You can get the manual on the link below page 14 will tell you how to change the time.
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/warranty/feefe62c036ce518b7afd6a03aaf618f84e5124e.pdf
SOURCE: I downloaded a .msf file from a Sony audio
Hi!
It seems like you've downloaded the wrong files...
As mentioned at Sony's FAQ:
MSGLIST.MSF is a file that contains information such as the order of
folders, playback order of audio files and recording date and time.
If user connects the recorder to the computer, the MSGLIST.MSF files are
displayed but do not delete or change these files. If these files are
operated, the saved files may be broken or the recorder may not work
correctly.
The right way to copy your recordings is explained here...
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Good luck and Best regards,
Pelu.
