Akai PDP4225M 42 in. Plasma Television Logo
Posted on Jan 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a PDP4225M 42 in. Plasma Television that will make a loud pop when turned on. A few months later there were horizontal lines that took a couple minutes to clear, next the lines were so bad the TV would shut down and the only way to get it on was to power off then on. Now there is a loud buzzing noise coming from the back of the TV also.
fordexpert
Level 3:
  • Master 5,692 Answers
  • Posted on Jan 25, 2012
fordexpert
Master
Level 3:
Answers
5692
Questions
Helped
1973230
Points
17063
Sounds like a bulb for the backlight or your power is arcing. In a dark setting, look at the back of the TV and see if the arcing is visisble.
3 Related Answers
Jerry Parmanand
  • 449 Answers
  • Posted on Mar 03, 2009
SOURCE: upon start up, I get fuzzy color concentration
change the color wheel.
Anonymous
  • Posted on Mar 08, 2009
SOURCE: Akai TV repeatedly turns off and on
Yeah. I had the same problem. About 1 month ago my AKAI PDP4273M1 TV began turning off...then on. I happened to stumble on a temporary solution. I held one of the buttons down on the t.v. without letting go...and what do you know....the tv stayed on. So I rigged it to where the button (the "source" button) stayed in and I stuck a small object into the hole next to it (a small nail in my case). The catch is you have to use the remote becase none of the buttons on the tv work. Wonderful...so...I got that fixed and then today my picture gave out about 75 percent. What a Piece of S%#* TV. That is all I can say. My 2 1/2 year old TV is a POS and is going into the dump. Can you say hello to a new VIZIO. Hope that helps. Remember. NEVER BUY AKAI TV PRODUCTS AGAIN!!!!!
Anonymous
  • 55 Answers
  • Posted on Apr 20, 2010
SOURCE: I have a Akai PDP4225M 42
I found the wall mount for your Akai. check link.
http://www.dealtime.com/xDN-tv_accessories--akai
2answers
TV turned on, heard loud pop. Now screen is very dark.
It sounds like the actual tube / lamp inside the unit has exploded. You will need to either get it repaired at a local TV repair shop or replace the TV. Unfortunately with that unit it is probably cheaper to just replace it.
I have a Akai PDP4225M 42" Plasma and I want to mount it on the wall, what type of wall hanger do I need. Thanks Pat
Akai pdp4225m have to unplug and plug back in for it to go on, then it shuts off after a few minutes
your cpu on the mainboard has lost its mind you need a new main board about 250 dollar job
3helpful
I have 42 in plasma.it turns on but no pictures.black screen.
Most likely either a Y--sustain or power supply board problem.
1helpful
Dell W4200 42 in. HDTV-Ready Plasma Snow and Horizontal Lines
go to the menu and try the plasma restoration first. that will take a few hours and you probably same the $350.
Akai pdp4225m 42 in plasma
Stevenson
The problem is the main input digital board. You need to replace that board. I can help you find the board, if you interested. Please, e-mail at [email protected]
Horizontal lines on Samsung Plasma
Sounds a lot like the Power supply board. But you have to check it out further to be sure. Email me back and we'll chat. GURU JAY
1helpful
No picture or sound
Add av input or change input settings
Top Akai Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Accurate TV Repair...
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
