Orange light flashin for colour black and paper but just put in paper and brand new inks wont print anything even though computer says 3 documents pending will make printing noise and turn out 1 piece of blank paper for a document that requires 10 pages to be printed! It is a pile of **** basically!
SOURCE: wont let me cancel a pending document
I used to have the same issue. It happened on five different occasions. I tired all kinds of steps to fix it and none worked. Finally, my daughter fixed it for me by accident. She tripped over the plug to the computer. After it restarted, I canceled the document, and it worked perfectly. After that, i knew what to do. Hope this helps@
SOURCE: documents keep pending and not printing
You need to either unpause the printer manager or delete all the queue's and restart he computer. Since you have not provided information on the operating system you use, I can not help you further.
SOURCE: Printer installed correctly however will not print.
1. uninstall your printer
2. restart your system
3. re install your printer
4. after installation take a test print
5. hope this will correct your problem..
6. otherwise, run Advance system care to fix your computer problems, such as registry errors etc., due to some registry problem are some other problem in your software makes like this problems.. download from the following link..its a freeware software..download it and install it, Press CARE to start the program.
Advance system care (registry cleaner)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
SOURCE: My documents are pending but the printer wont
Unplug and replug the printer into your PC, if possible use a different USB port. If that doesn't work, restart your computer.
SOURCE: everytime I try to cancel the pending document it
first do a right clickon the printer icon
select run as administrator if there or else try cancelling the document
if still does not work
go to run and type "services.msc" and it will take you to the services page
in the services page look for a service "print spooler "
restart the print spooler
and then try deleting the documents .......................... hope this should work for you let us know wat happens and we will help you accordingly ......take care ............god bless you ...........thank you (HAMID)
