Question about Filter Queen Majestic Canister Vacuum
How do I get rid of the bad smell coming from my filter queen
Runs well, great suction but smells like **** when I run it
Posted by Carrie Fegley on
Mark Smith
    Novelist:
  • 147 Answers
Change all 4 of the filters, and wash the dirt container with soap, water and a little bleach. The only other thing that would cause a bad smell would be the actual motor, but that would be more of a burning smell. Good luck!
Posted on Jan 25, 2012
5 Related Answers
Anonymous
  • 8 Answers
SOURCE: Our Filter Queen is now making a loud and strange
thats got a realy bad motor. I don't know if you can still get motors for the model in the pic if that is your moddel
Posted on Jun 12, 2009
Anonymous
  • 430 Answers
SOURCE: My Filter Queen just started making noise from the
The motor will need either a rebuild with new bearing, or replacement. Parts should be no more than $100 .EASY project. 20 minutes max fro a pro shop. If you can tie your shoes you can do this one yourself.
If replacing, upgrade to a ball/ ball ( double ball bearing) motor, same height, generally an AMTEK Lamb. A ball ball motor will give longer life
Under the cap you have removed are 3 screws.
You will detach them last. Note they are slightly offset in their pattern.
Open the vac as though changing the cone. Remove the plastic cone by undoing the center screw. Remove the inner filter disc and change . This should be changed every 6 months...
Now you will see three, screws or nuts in a triangle pattern. Detach them. Remove the rubber switch pedal from above .
.Now detach the upper 3 screws and the motor housing will lift off. Voila. Inspaect the cord inside and out for wear at it's socket. Now is the time to shorten if required.
There should be an insulating disc about the size of a coin between the motor top and the screen below the vac handle. You MUST reinstall on the new motor in case of a short in the vac.
Remove the foam or felt "muffler" and clean or replace.
Remove the wire nuts and note the wiring pattern for the switch, motor and power head. Note the motor position versus the cord. Mark with felt pen and reinstall the same.
Do not twist the wires when reinstalling, only twist the wire nuts. Check that they are tight and reinstall in opposite order.
Please post back if tehre is a problem or this helps
Posted on Oct 04, 2009
Testimonial: "Thank you so much!!!! Now I have to buy a motor."
Anonymous
  • 430 Answers
SOURCE: how to change upper filters?
Open the vac as though to change the cone and remove the plastic inner cone with the slotted screw at the bottom.. Underneath you will find a 5" disk , likely coated with fine dust.
That is the one which needs to be changed. Around that disc will be three more screws holding the upper housing onto the vac. These ones are accessible from inside, if changing the motor.
Below the handle of the vac there is a serial number ring and three screws in an offset triangle. If you remove these and the rubber cover for the toe switch, the vac housing will come off. This will reveal the `foam or cotton ``muffler``. You can replace it or wash and dry it if foam. It acts as a muffler more than a a filter....
Posted on Oct 17, 2009
crash_59
Chris Nomland
  • 124 Answers
SOURCE: Filter queen vac 2 years old suction poor cleaned
Hi, Did you change both the cone and the filter on the top lid? If so, ther may be a leak in the machine breaking the air tight vacuum. When you put it together make sure its in properly and tight. Let me know if this does not help, I will look at something else. Chris
Posted on Feb 09, 2011
My dyson DC50 smells when hoovering
many things can make it smell bad wash filter top and lower in hot soapy water and rise well and dry well in sun
wash bin and all it's parts in hot soapy water and dry well
clean brush roll and check for any bad smells in head
could be from motor over heating or near to failing if above does not get rid of smell i would say it's the motor
May 31, 2014 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson filter smells like mold after washing
Patry816:
It might not be the filter! The hose, canister and suction vanes on the motor also can cause that smell!!
Jan 06, 2013 | Dyson DC23 Animal Vacuum
MOTOR RUNS WITH NO VACUUM PRESSURE
Sounds like the belt should be replaced. It maybe turning the brush, but if you smell burning rubber, its slipping and not turning the brush with as much force as it should. Changed the belt. Check the air suction path. If the suction is reduced, something is blocking it. Check the bag (if it has one) and all filters. If the machine picks up any liquid, it will reduce the air flow through the filters and bag. Change the bag and filters. If this is an upright, you may find caked on dirt under or in the area of the brush.
Nov 28, 2011 | Hoover Vacuums
How to change upper filters?
Oct 17, 2009 | Filter Queen Majestic Canister Vacuum
Our Filter Queen is now making a loud and strange sound along with smoke coming out of the top... smells like something is burning. Help?!
Jun 10, 2009 | Filter Queen Cheetah II Ash - MU305...
Upright Vacuum Cleaner Lost Suction
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Sep 24, 2008 | Kenmore 31913 Progressive Direct Drive...
When the vaccum is running the motor gets hot & smells & is very noisy.
Sounds like yu may have a clog, either in the inlet by the brush roll, or the hose. If the hose comes loose, see if there is suction there. If no suction then it is clogged. If suction, then the inlet maybe clogged.
Jul 22, 2008 | Dirt Devil Reaction Twin Cyclone Upright...
My vampyr 5040 vacuum has lost suction and is starting to smell. can it be fixed economically?
Lose of suction can be from a clog in the hose, dirt inlet by the brush roll, or the motor running slow. A smell, depends which, if a rubber smell, then could be a bad belt and/or brush roll. An electrical smell, could be the motor going bad, if it is the motor, it will need to be replaced.
Apr 23, 2008 | Vacuums
Motor gets hot in moments and shuts off
True, the motor has safety measures to stop it from overheating... that's why it shut down. You smelled something, so some kind of damage was done. It's possible that the over temp switch itself got fried. Doesn't sound too good from here.
Mar 08, 2008 | Filter Queen Majestic Canister Vacuum
Filter Queen Majestic Canister Vacuum Logo
624 people viewed this question
Top Filter Queen Vacuums Experts
Marvin
Marvin
Mike
Are you a Filter Queen Vacuum Expert? Answer questions, earn points and help others
