Have vcr/dvd combo connected with red/white video and yellow audio, but cannot get both sound and video from vhs
I have connected my Toshiba vcr/dvd combo to the Samsung tv using red/white/yellow. VHS appears on V1, but no sound. Sound from VHS overrides sound on satellite channel. HOw can I get both sound and video from VHS?
Sorry. I misspoke. The unit is properly connected (r/w = audio, y = video). Getting sound on satellite channel, and video on V1, but no sound on V1.Sorry. I misspoke. The unit is properly connected (r/w = audio, y = video). Getting sound on satellite channel, and video on V1, but no sound on V1.
When I select VCR as the source, I get the video, but no sound. Upon switching to TV as the source, I get the current channel picture, but the sound from the VHS. Very strange.When I select VCR as the source, I get the video, but no sound. Upon switching to TV as the source, I get the current channel picture, but the sound from the VHS. Very strange.
You can't post conmments that contain an email address.
Okay, Do you have the input selected? There should be a Video in select somewhere. Also do you have the cord plugged into an output rather than an input? I did that once.Okay, Do you have the input selected? There should be a Video in select somewhere. Also do you have the cord plugged into an output rather than an input? I did that once.
Y is not compatible, it is one of the three inputs for "component" video which consists of Red, Green, Blue channels - RGB. The single yellow jack is "composite" video and the red and white are for audio. If your TV has HDMI inputs which are commonly used for HD TVs now, then you should be able to find an A/V adapter to convert the composite video and the audio to HDMI. HDMI carries sound as well as video. You may also find a composite to component adapter which will take the single composite signal from the combo device and break it into the 3 RGB signals for the TV. The thing is that the quality will not be HD for any of these, but then anything on VHS tape or home made DVDs will not be HD anyway. Try searching amazon and ebay, possibly newegg.
Hi, In order to watch either DVD or VHS on your TV ,you need to make the following connections ..
You need to connect "DVD Player / VCR Combo" to" TV " as (Audio/video output
of DVD Player / VCR Combo -TO- Audio/Video input of TV) ..
use either "RCA analog (red/white +yellow ) " or "SCART "or
"Optic " cable.(any standard optical cable )...if exist ,optic is the best way to
connect it..Remember your DVD Player / VCR Combo 's "OUT" goes into" IN "of the TV ..
pls also
remember,wherever you connect your DVD Player / VCR Combo on your TV ,you should switch
the source selector accordingly to correspond to the connection on the
back...
Hope this helps!..if more help requires pls let me know. Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
The yellow pin is for video, while the white and red pin are for audio left and right.
So, your wires will be connected to video and audio "OUT" from your player and connected to "IN" respectively on your TV.
That's how it gos. Its a input and output law. The Player will be sending out the pictures and sounds (OUT) and the TV will be receiving from the other end (IN).
Its as simple is that. But if there is still no picture, then cross check your video wire (yellow), maybe its bad.
ACCORDING TO THE TECH AT TOSHIBA: THE UNIT MUST BE CONNECTED TO THE TV BY AN HDMI CABLE FOR THE DVD PART & (ON THE BACK-RIGHT HAND SIDE OF THE COMBO) YOU NEED TO CONNECT A SET OF THE RED/WHITE/YELLOW CABLES FROM (VIDEO) "OUT" OF THE COMBO & "IN" TO THE RED/WHITE/YELLOW TV(AV-1) PORTS FOR THE VCR PART TO WORK.
Do you have a newer TV or a older one lets start with a newer models does your tv have 3 or more jacks on the back or front you should see a RED, YELLOW and WHITE if you have a HDTV you should see more. (LETS HOOK UP) Did your DVD/VCR come with a cables if not you will need to buy at least 2 they are called RCA cables Lets start with the dvd/vcr combo on the back you should see a (LINE OUT) this is where playback or your picture and sound come out. On the back of the TV you should see a (LINE IN) this is where you plug it in to. RED goes to RED, WHITE goes to WHITE and YELLOW goes to YELLOW. To Record you will need to hook up the line in on your combo and the line out to your tv. ( IF YOU HAVE AN OLDER T.V WITH NONE OF THOSE JACKS ) you will need to buy a RF- MODULATOR the are cheap it is a box that let you hook a cable wire to a little box and the RCA jacks to you combo and you will turn your tv to channel 3 or 4
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
yes , this is why , on your dvd there is a "yellow for video" output on it ,and then there is a "red output jack for right audio"
and then there is a "white output jack for left audio" does your tv have these inputs?
the blue , green and red "RCA JACKS" are called " composite video" which seperates the colors of given video
the red and white RCA jacks are for right and left audio and are required when using composite or the yellow video jack
there is also a "s-video" connection that is one cable but seperates the colors for better picture quality ( dvd player only)( vcr and tuner do not work with this)
then there is a optical or coax digital connection for a reciever that decodes the connections audio digital signals for dolby digital surround sound
RCA plugs (the yellow, red, and white outlets you speak of) consist of a video plug (yellow) and stereo plugs for audio (red and white). Just match the colors from the DVD RCA colors to the RCA hook-ups on the TV (ex. Yellow the Yellow, White to White).
You don't need to worry about the red one, it just makes the DVD player play stereo audio. Instead, you'll have mono, which is fine, and most modern players can detect mono and switch it for you so don't worry about changing settings and what not (unless you're missing sound on one side.)
