Question about Locks & Locksmithing
The only thing I can see on the safe is the number EX200 6029121. It is cream in colour.
I read this elsewhere. it's worth a try...
"I had the same problem, batteries dead and i could not find the keys. I read on the internet that if you get a hairdryer, and heat up the front of the safe where the keypad is and where the spare key goes in this will work, i thought anything is worth a try. So i held the hairdryer there for a bout 15 mins and what happens is the heat slowly boosts the battery life, enabling you to open the safe. You will notice that you start to get a beep noise from the key pad. even though i was getting a beep from the pad it didnt open straight away but after about 10 mins i retried the code and it worked. Make sure you replace the batteries immediately before closing the safe again "
Posted on Feb 22, 2012
Hi , i Pressed the red button to put the new password but the door was closed before i enter and confirmed, what can i do to make the door open again specialy that the old password was deleted !!!
Posted on Dec 02, 2014
Simply contact the manufacturer for a new key. You'll fill out a form and send it back with the charge for the key. Look up the maker on the internet and have the serial number and model to give them. Next time keep the key in a special hiding place.
Posted on Aug 28, 2014
SOURCE: I need a replacement key
I was locked out of my Honeywell safe after battery died. I ordered a replacement key from firstalert.I was required to photocopy the receipt and type out an witnessed affidavit stating I own the safe. About 3 weeks later I found my spare key,4 days after that the replacement key arrived in the mail ($10.95 money order for that key). The other two spare keys were in the safe, I did not think the batteries would die so soon. Crappy factory batteries that came with the safe.
Posted on Mar 16, 2011
SOURCE: I bought a Safewell SE
The red button is on the inside of the safe. It is on the back of the door. Usually by the hinges
Posted on Dec 19, 2010
SOURCE: I have a Safewell safe
I know you don't want to hear this but to get into the safe without destroying the contents you will need to take it to a full service lock smith who will probably have to cut it open. That is the problem with the electronic safes - work great until the battery goes dead and then unopenable.
Posted on Aug 15, 2011
SOURCE: i hv a safewell safe.
You'll most likely need help from a locksmith. Basically, the lock can be picked, to get the safe open. There might also be a factory pre-set code.
Posted on Aug 26, 2011
SOURCE: I have a safewell ex200
I have seen many similar problems here...not sure if this will work for your safe, but it is worth a try...
Click here
heatman101
Posted on Sep 17, 2011
Jul 01, 2017 | Ice Cream Makers
Jan 14, 2016 | Ice Cream Makers
Apr 08, 2015 | BMW 318 Cars & Trucks
May 29, 2017 | Safe International Mesa Safe Company MH101...
Jan 07, 2011 | Hitachi Computers & Internet
Dec 07, 2009 | 2005 Chevrolet Malibu
Apr 29, 2009 | Musso Stainless Steel Pola Ice Cream Maker
Jul 29, 2017 | Girmi GL14 Gran Gelato 1 Quart Ice Cream...
9,019 people viewed this question
Thanks for suggesting the use of a hairdryer. Tried it but unfortunately no luck. Thank you anyway.
My friend has a safewell but she lost the keys andcan't remember the combination number please help
I have the same safe they have a security nu it is 159 dial that nu it will Open Change the batteries immediately
It really works. Many thanks
