Code for HT-391 regent home theater remote
Universal codes for Regent home theater remote
  • Scott Webb
    Scott Webb Aug 13, 2019
    Go buy a GE Ultrapro universal remote from walmart for 10 bucks. The code is 1476
My name is travis i have a regent home theater system model ht-391 i just bought a universal remote is there a code for the system
Posted on Mar 13, 2013
  • Scott Webb
2 Suggested Answers
sandipmistry
SANDIP MISTRY
  • 57 Answers
SOURCE: need code to program other remote
For this reason, no one can help other than the SONY AUTHORISED PERSON. These codes are not given to customers or any other personnal other that SONY PERSONNAL. So you need to contact your neartest SONY SERVICE CENTRE.
Posted on Apr 23, 2009
Anonymous
SOURCE: Need Vizio TV code for my Samsung HT-X50 home theater remote!
Mine is 5. Press the TV button and let it go. When it quits glowing press the power button and hold it down. Then press a number (1-86) on the keypad while holding the power button down. If the TV turns off, you are done. Press the power button again and the tv should come on. If it does not work. Release the power button for a second and then repeat with a different number until the tv turns off.
Posted on Jul 24, 2010
I need a five digits IR code for a Regent HT 391 home theater system
made by Lennox and they are out of business. You can only do it if you have a 'learning remote' according to my research.
Feb 21, 2016 | home Audio Players & Recorders
Regent home theater remote control codes
http://farmerstel.com/remotecontroluserguide.pdf
How to set up universal remote
All remotes are not the same . You may have to google your remote using the brand and model number.
Oct 14, 2014 | Audio Players & Recorders
How do i get a Regents HT-391 surround sound system to play sound from my Logitech Revue with Google TV?
More than likely the regent system is needing and alternate audio source, via- analog, digital coax, optical ect... HAs it always been this way, or use to work?
May 22, 2014 | Logitech Revue with Google TV Refurbished
Need manual HT 2004
check this link to download your user manual....http://rexonavn.com/regent-ht-2004-home-theater-system-manual-manual-manual.html
Thanks for rating Good luck
Jan 13, 2011 | Audio Players & Recorders
I have a phillips universal remote and a regent dvd player, the codes i got from phillips web site do not work right. i need other codes
The universal remotes always comes with the supporting codes for the models that it is intended, if there is no help then you must consult to see if the remote supports the model of the player you are having- Regent.
Get help from the dealer from whom the remote was purchased..ask for manual.
Sep 30, 2010 | Televison & Video
Need to find code or whatever to get direct tv white remote control RC 65 to operate regent HT-2004 home theater system.
You can get the manual and codes on the link below. If you do not see your receiver then do a code search on page 9 under SEARCHING FOR TV, AV1 OR AV2 CODES.
Here is the only code in the manual for you receiver.
Regent 31437
Page 9 under CONTROLLING OTHER COMPONENTS will tell you how to enter the code.
Here is the manual on the link below.
http://www.directv.com/learn/pdf/Remote_Controls/DIRECTVRC65forWeb.pdf
Good Luck and please rate 4 thumbs up for the free answer
Aug 01, 2010 | Audio Players & Recorders
3,660 people viewed this question
Ekse
 Grubhead
Grubhead
