Washer stops mid-cycle. Technician initially replaced the 'control board' but it still stopped mid-cycle. Then they ordered a new 'wire harness', but it doesn't plug into the machine correctly. How do we know if any of these things (very spendy) really needed to be replaced and will the machine ever work properly.
SOURCE: lg wm2277hw washing machine
sorry to say it but i think you still have a faulty hall sensor.
Try another one and send the last one back as being faulty.
It means the motor gets the power but the hall sensor stops it dead in its track
SOURCE: My LG Clothes Washer has
oe means drain error (outlet error)
Poss causes:
drain hose kinked,
filter blocked,
pump impellor blocked.
Hope that Helped
Please Rate Me
George
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
SOURCE: LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
SOURCE: Humming sound washer won't spin
It sounds like you have a hall sensor failure, if your machine fills with water and then does the buzz thing without the drum ever moving in the cycle.
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
