I have a very thin (1/8 inch or so) dark edge printing along the right edge of the paper on the entire length of the paper when it comes out of the printer. I'm wondering if this is a printer problem that needs to be fixed or if the cartridge simply needs to be replaced. Thanks for your thoughts.
Hi!
Here is a link to the manual to Samsung ML1740 laser printer (the "Troubleshooting" part)
Hope it will help!
https://manualsbrain.com/en/manuals/1437656/?page=95
SOURCE: dark lines on printer paper
Possible.... other possible solution is a dirty drum... try changing the toner cartridge and cleaning the drum
SOURCE: Samsung color fading-light on lft side to dark on rt side
i want to download the driver softwere of samsung clp-300 series vista ultimate supported
SOURCE: printer not printing dark enough
go to the print settings select the dark scale
u can get print darker than the previous
SOURCE: Samsung ML-1710 Printer - see below
Try to put new cartridge in.If this doesn't fix the problem, it can be that the fusing unit heater roller teflon coating is worn out and this roller needs to be replaced.
SOURCE: black text only printing dark on right side of
My solution
(CAUTION: Never loss balance while tilting printer! You may drop and damage your printer! Hold the printer firmly all the time! Ask someone to help you if needed!)
Here, front of the printer is where you can access the cartridge, back of the printer is where you connect the power cord and USB cable, left is your left, right is your right.
1.Lift the front to keep the printer tilt to its back at about 45 degree
2.Power on printer while it's tilted back, wait untill green light is on
3.Open the front door, red light will be on, then close the door, printer will start up again,wait untill green light is on
4.Repeat step 3 once again, then put the printer back to level position
5.Lift the right to keep the printer tilt to its left at about 45 degree
6.Open the front door, red light will be on, then close the door, printer will start up again, wait untill green light is on
7.Repeat step 6 once again, then put the printer back to level position
8.Print some test page to see if there is any improvement of black print quality.
You may try several times and print several pages each time before you finally cure the problem.
Good luck! And do it safely!
