The hinge for the lid has broken and now the lid won't close, causing an error message on the printer telling me to close the lid. The printer won't print or do anything because of it. I want to know if an new hinge can be fitted.
SOURCE: hinge is broken on my lexmark X6500 so cover
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/john_472b46f833fc3109
SOURCE: Lexmark z617 printer not working, printer
When you say "printer cartridges shooting from side to side when poweed on or lid opened & closed", do you mean that it's banging from side to side? Turn off the printer. Remove the cartridges from the printer. While the cover of the printer is open, check inside for anything out of the ordinary like any tapes or strips that are loose. If none, turn off/on printer and reload the cartridges. If the banging noise is still present, I suggest you contact Lexmark Technical Support to further investigate the problem. It might be a mechanical problem in the printer.
SOURCE: The left hand plastic hinge on my lexmark x6575 is
I am including the details of teh Lexmark Parts Center.
Customer Support Representatives are available Monday - Friday from 9:00 am - 6:30 pm EST
E-mail: [email protected]
Phone: 1-877-577-2787
Fax: 1-800-258-4880
SOURCE: Lexmark E342n Laser Printer Fuser Error
920 Fuser Error
Indicates that the fuser is below temperature when printing
Do a Fuser Service Check
SOURCE: My Lexmark X7675 is pulling the paper to the left
Hello sir; Check the paper tray at the bottom there should be have something especial on the left side of the tray.
Problem solved by the solution to the X6500 question about the same problem. Took out the spring now the lid closes and printer works again. So, so happy!
