EVEN AFTER SHARING THE SCAN FOLDER, I STILL CANT COMMUNICATE TO THE COMPUTER FROM THE SCANNER WHEN I TEST THE CONNECTION.
SOURCE: Scanner won't communicate with computer
Try this,
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
Right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready toi use, re-connect the scanner USB lead.
Windows should re-install the drivers and tell you the scanner is ready to use................hopefully!
SOURCE: HP OJ 6500 with windows7..Scan button on scanner is not working.
The reason that you are unable to scan through the printer is, you are missing HP full feature software and driver.
Please download and install it from the below link
DOWNLOAD
Regards
Rizwan
SOURCE: Canon Pixma MX850 won't scan - says 'set the pc to start scan'
Do you have more than one PC connected to the scanner? I have both a PC and a Mac connected to it, and I think my scanner is trying to connect to the Mac, which requires image capture software to be installed, rather than the PC. Don't know how to tell it to go to the PC, though...
SOURCE: canon mp 220 scan problem
Check the following information........
http://en.kioskea.net/forum/affich-451452-canon-mp-220-printer
THIS PROBLEM STARTED AFTER CHANGING FROM WINDOWS SERVER 2003 TO WINDOWS SERVER 2008.
