Drips
SOURCE: water leaks from shower head while bath faucet is running
sometimes there are orings or gaskets that get tore in assembly one of those may be bad,or if it is around the threds you might try wraping teflon tape around the thred once or twice.hope this helps
SOURCE: I have a movatio shower head with a grohe allure
not the shower head ..its the hot and cold handles...
SOURCE: I have a american standard 5
Don't forget to turn your head upside down and look underneath the spout body. There sometimes is a little star screw or phillips screw securing the spout. After removing the little screw you can get you a 3/4" pipe thats about a foot long and stick it up the tub spout opening. This will give you leverage to turn the thing loose. Good luck cause getting this thing loose is a bi.ch sometimes.
SOURCE: replaced shower valve. still drips from tub spout
The cartridge has 2 or 3 o-ring type seals around it that feed the water through, it picks up both hot and cold and mixes them. Some cartridges are replaced as one, some you have to replace the seals, just take the faucet info to the hardware store and match it up. I think the diverter is for the shower. It sends the water up instead of out.
