Question about Korg M50 88 Note Workstation
How to reset the korg m50
Waldy Del Rosario
    New Friend:
PLEASE HELP ME... this appeared in my KORG M50.. says. LOADING OS FAILED..... Is ther a solution to this...
Posted on Apr 02, 2019
charlie rodriguez
    Novelist:
  • 152 Answers
Hello, The way you reset a Korg M50 is by switching it to global mode and pressing the small arrow at the top corner this brings down a list with options you press reload all factory data and pre loaded pgm, hit that then press the reset button it will ask you if you are sure click yes and that's how it resets. how this helps
Posted on Mar 30, 2015
2 Related Answers
5011
  • 11 Answers
SOURCE: Where can I get the Korg m50 service manual or
http://www.korg.com/SupportResults.aspx?productid=413 just click here :)
Posted on Feb 28, 2011
zacharswift
I was just on the phone with partsisparts.net 800-590-0014 and they said the m50 service manual will be availible for purchase and download on their website tomorrow (9-23-11) I hope this is true. as for a parts list for the M50 I am still looking for that myself. I hate the poor quality of Korg.
Posted on Sep 22, 2011
My korg m50 touch panel recently not working
see the link for repair or replacement. Known problem by the looks of it.
korg m3 touch screen not working Google Search
Jul 24, 2018 | Korg Music
Korg m50 gm sound not plying on my keyboard
try resetting it to its factory setting,
Sep 05, 2016 | Korg Music
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
May 01, 2015 | Korg M50 61-Key Music Workstation Keyboard...
My corg m50 board not orking gm not ork
Your best bet would be to contact Korg directly. Here is the link to their USA support page
Contact KORG
Feb 11, 2015 | Korg M50 61-Key Music Workstation Keyboard...
Korg m50 freezes, read in other forums that the problem may be to replace 2 capacitors, do anybody knows wich ones? or have a solution?
Hello, I own a Korg M50 myself and I had the same issue, its a quality control issue at their factory but, I may have a solution for you I found at a Korg forum. the issue is with these teeny cables inside the synth. you open the rear panel and firmly press each teeny cable into the terminals again and re attach and secure them firmly just finger push them all into their teeny sockets. this should stop the freezing I tried it the synth played all night with out freezing . I hope this helps other wise the solution with the capacitors is simple you order a new mainboard but they run about 400 plus. but try my solution it may work for yours this answer comes from a korg tech, he stated 90% of this freezing issue he has encountered has been these loose teeny cabling adapters, hope this helps, Have a great day..
Jan 27, 2014 | Korg M50 61-Key Music Workstation Keyboard...
Moving to Canada Korg M50 - 220V to110V ?
110 will not damage it, just will not work, if built in power supply should say on the rating plate next to power input the voltage it is able to take, a lot of units are rated 110-240v some will have a small switch to change over from 110 to 240. Other than that, you will need to get a step up unit to supply 240 from 110 just a small transformer unit.
Mar 06, 2013 | Korg M50 61-Key Music Workstation Keyboard...
Korg M50 keeps freezing up how to fix took it to repair and it still does it
Well looks like you have a capacitors problem. I had this problem too and a friend soldered two new capacitors in place. You can find information on the korg forum but most important is to know where the capacitors are located
http://www.korgforums.com/forum/phpBB2/viewtopic.php?t=92395
Dec 07, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Korg m50 freezes after 10minutes
Hello I have this M50 61 key korg model, I had the same issue the fix is simple remove the back cover on the unit, carefully push in all the small cables reattach them well do it to all the small connectors these cables get lose and cause this issue, good luck let me know if that helped I fixed mines that way its been working excellent since. good luck..
Jun 08, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Korg M 50
Korg Support advises that they can either provide you end cap or direct you to a retailer. CLICK HERE
May 23, 2012 | Korg M50 61-Key Music Workstation Keyboard...
Where can I get the Korg m50 service manual or parts manual?
Feb 26, 2011 | Korg M50 61-Key Music Workstation Keyboard...
Korg M50 88 Note Workstation Logo
1,398 people viewed this question
Top Korg Music Experts
Poul Brinchs Larsen
Becketts Music Ltd
Becketts Music Ltd
Are you a Korg Music Expert? Answer questions, earn points and help others
