I have had the hardware and software analyzed by computer repair people. Replaced the hard drive recently and that is not the problem. There is only Windows 7, MS office, Google Chrome and Adobe Reader installed. I do not have any other files (including documents and music) installed on this computer.
SOURCE: sony pcg frv 37
Well there are some things that might help you with this...
Here are some ideas...
and get a newer one :)
SOURCE: Sony Vaio VGN-SZ460N Freezes during Full Recovery
Probably a memory problem even though it doesn't show up on a memory test. Enter the bios and select the option for default setup, "not the optimized setup". Also if you have more then one memory module, remove one and try the install, if you have two try using the one you removed first as the only memory module during the install process. If you have any cards plugged into the computer, remove them all before starting the install. Also all usb cables. Make the system as simple as you can for the new install.
SOURCE: Registry File Failure c0000218
Try this: Reboot and select Recovery Mode, then from the c:\windows prompt type: chkdsk
Let it run through checkdisk then try it should boot up.
SOURCE: bluescreen on sony viao vgn-z46gd while installing
Bluescreen occurs becoause of compatibilty issue.
check this link out : http://esupport.sony.com/US/perl/os7upgrade.pl?mdl=VGNSZ480
It may help you in taking further action.
SOURCE: How do i get drivers for my touchpad and keyboard
to be frank about this query, windows 7 does not have proper drivers for most of the device, which win XP and vista supports.
it is new operating system and it is still not fully supported by most of the previous versons of windows.
only solution is to down grade your system (laptop) to vista so that it will be compatible.
thank you
colticz
