Question about Toshiba Tecra 8200 Notebook
Wifi will not connect on dongle - Toshiba Tecra 8200 Notebook
Posted by madmax474 on
Anonymous
    New Friend:
Has your pc installed the dongle correctly?
Posted on Jan 23, 2012
I have a 40" smart tv with built in wifi but understand u need a dongle to be able to connect. Could u please tell me which dongle I need please?
If WiFi is "built in", you do not need a dongle.
It may be "WiFi ready" in which case you add a dongle.
But you would need to check the manufacturer's website or the owner's manual to find out the recommended models of WiFi dongle you can use.
Have purchased a 50inch luxor television when i
The WIFi dongle maybe loose or has lost its settings.
Make sure it has a good line of sight to the router and is not hidden behind the TV.
You can set up the settings manually
.The other thing which may help is to go into TV menus under network and change from 'manual' and use your own details;
Try these settings;
IP - 192.168.1.100
Subnet - 255.255.255.0
Gateway - 192.168.1.1
DNS - 8.8.8.8
How can I add an external WiFi Donegal to a median life pad
WiFi dongles are developed for PC usage. A tablet, does not redirect internet info to or from a USB connector. For every USB device you need a driver and a program on a computer. As long as you don't have the programs or app for any dongle, no use to connect any dongle to any tablet.
My luxor 40inch smart TV will not connect to Brightbox router viA wifi dongle? Please help
You TV cannot use a wifi wireless dongle. The usb port on your tv is for connecting a usb drive for pictures or movies. There is no place to load the drivers necessary for a wifi or bluetooth dongle.
Wifi headphones
assuming that it is a wireless head set, will you need to plug in the usb dongle into the television. there might also be a sync button on both the dongle and headset that you will need to press, first on the dongle then the headset.
How can i conect my both pc via wi-fi.? Pls help.! Thanks
In the market wifi dongle will available for app. 750 INR. Purchase it and click on the button on dongle to search wifi available then connect to your wifi with password or some routers will allow to connect by pressing button on router. -www.surisurender.com
My Lg 32ld550 and usb dongle won't "see" my wifi network. Can't get it connected.
Che\k in device manager if the dongle is working properly. For hat in run type "devmgmt.msc" and find the dongle and double click on it. If it says some problem try re-installing the drivers..if it says device is working properly then restart the computer and search for the wi-fi. If it still doesnt recognise take the dongle to a hot spot like a cafe and check if it can detect wifi. If it detects else were its and issue with the wifi at home..if it doesnt recognise the wifi in hotspot its an issue with the dongle.
Hope this helped.
3helpful
Is wifi is compatible for N73?
N73 does not have the hardware to connect to wifi but still u can
Try this...
1. Buy a bluetooth dongle.
2. Connect the bluetooth dongle to your laptop and enable bluetooth in N73.
3. Get internet in N73 through laptop.
(More info : http://web.singnet.com.sg/~kinston/Bluetooth%20Internet.htm)
U will not be able to connect to public wifis only to ur laptop...
Toshiba Tecra 8200 Notebook Logo
Top Toshiba Computers & Internet Experts
Ekse
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
