Cameras Logo
Anonymous Posted on Jan 23, 2012
Had power outage now will not turn on - Cameras
  • Anonymous Jan 23, 2012
    brandon not a camra a pictur frame
Anonymous
Level 3:
Guru:
  • Master 722 Answers
  • Posted on Jan 23, 2012
Anonymous
Master
Level 3:
Guru:
Answers
722
Questions
11
Helped
282297
Points
2127
Is this a camera? Try looking for a reset button; if it contains a rechargeable battery, it's very possible that the battery was permanently damaged if the device was plugged in, which sounds like what happened. I suggest purchasing a new battery, or if you have a spare already, try using it. Please let me know if you need further assistance.
Networking issue after power outage
Turn off the modem and router, wait a minute, then turn them back on. It's also possible there was a power surge proceeding the outage that damaged one of the devices.
tip
Wii won't turn on after a power outage.
Hey, recently had a power outage and now your Wii won't turn on?
Well unless your Wii is completely fried from the storm then this should work (It has for me every time I have had an outage).
After you find out it's not getting power then just unplug the power cable from the wall and from the Wii. Normally I unplug it for about 12-24 hours then you go plug it back into the wall, plug it back into the Wii, look at the power button and if it is red/orange then it has been fixed and you should never have a problem with it again unless you keep it plugged in during a thunderstorm/power outage!
This has happened to me about 8 times and this method worked every single time!
Power outage
its gone when themachine is turned off from the power outage, have them resend it
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Sound quality has diminished after power outage
Tries unplug,replug an hour later,let the tv reset itself back to factory setting.After,turn on the tv,go to the menu,go to sound on ur menu go down to reset the sound.The functions should go back to normal,not than.Ur tv Tuner signal board have a short,in the power outage occurance.
Will not turn on. after a power outage.
HI. this will happen during most outages. there is a fuse located inside the power supply device that is used to power your unit. simply remove the cover off the power supply box, and replace the fuse inside. this will correct the issue.
***((Now, if the fuse is OK, and not harmed, this will confirm that the power supply has failed. It should be replaced in this case))
3helpful
Wont turn on after power outage
there is a power supply board that goes bad in this set. Good luck
2answers
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
1helpful
ILO 2706 TV WONT TURN ON
This TV might have been affected by the power outage even if it was not ON at that moment. There is a standby voltage still present even when OFF and connected to the AC line.
There might be different failures on this TV:
1. The power supply might be defective after the power outage.
2. The main board could also be defective since the power supplies for today's TVs are not well regulated and once the voltage getting to the power supply increases, the standby voltage voltage will also increase damaging voltage sensitive components like the microprocessor or memory circuitry.
Let me know if you require further assistance.
I had a power outage!
Hi there!
Power outages and lightning are the main causes of Electronic failure. It has obviously affected your TV and will need to be seen to by a repair technician if you are not skilled to do so. Regards and good luck, JUS004
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
