Question about DISH Network 54 1 Ir Vip 622 722 Dvr Remote 222
Dish changing channel to new recording while watching *pre-recorded* program
When I am watching a pre-recorded program on Dish, a new timed recording will start and the Dish will automatically turn to the new channel that has started to record. This just started happening a couple of weeks ago - before I could be watching an already recorded show, and the timers would start without interrupting what I was currently viewing. We have a lot of timers set, and it's very annoying to be watching a playback of a recorded show and have it stop and switch to the new recording in the middle. I can go to my recorded shows and start it up again, but it's annoying and a pain. Is there a setting I need to change somewhere? Thanks!
Posted by rjvdw on
  • 2 more comments
  • rjvdw Jan 30, 2012
    I tried unplugging to no avail - it is still switching channels during recorded programs. I did realize that it may only be switching to programs that are being recorded straight to our external hard drive, rather than the DVR (which we started doing a couple of weeks ago, hence the problem being noticed a couple of weeks ago). Could be some kind of glitch with that? Thank you for your response - we aren't ready to exchange our receiver at this point, but if other errors occur we will call Dish or contact you. I appreciate the help!
  • dish
    dish Jan 31, 2012
    The EHD shouldn't cause any problems while recording. If you're able to isolate it, or can test recording as normal, that can provide more insight. Just give us a contact with what you decide to do!
    Tommy Faust
    DISH Internet Response Team
  • rjvdw Feb 08, 2012
    I was able to test it - when recording to the DVR there was no problem. I have isolated it to a problem only when recording to the EHD. I still don't want to go through all the hassle of changing out the receiver for that, but it would be great if there was some kind of fix that could be sent through an update or something!
  • dish
    dish Feb 08, 2012
    That's a great suggestion, rjvdw! I will be sure to pass that forward, but at this time we have no updates on that functionality for the equipment.
    Tommy Faust
dish
  • Official Brand Answer
  • 263 Answers
Rjvdw,
Try unplugging the receiver for 10 seconds then plugging it back in, and see if the problem is resolved. The receiver should only switch if you are watching live TV instead of a recording.
If the problem persists, and you are for sure not on Live TV, the receiver may need to be replaced. If it continues you can send me an email at [email protected], and I can assist you further!
Tommy Faust
Posted on Jan 27, 2012
Hr836t how do i watch different channel to one recording
This unit has only one tuner, meaning you can only watch or record one thing at a time. Depending on your TV and how your equipment is installed, you may be able to split your antenna/ cable line and record on your DVD and use your TV tuner to watch another program.
Feb 02, 2014 | LG V271 DVD Player/VCR
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
We have Dish Network VIP722 on only one HD tv at this time. When recordng HD PPV, we are unable to change channels without getting message that recording will stop. Menu&gt;Preferences&gt;Record...
This is a problem that many have. If you are recording on TV1, and the receiver is in dual mode, then you are only able to watch what you record. But you can set your recording to TV1, and then put the receiver into single mode, and switch from the recording to live TV.
Becki Barned
DISH Network Customer Service
Mar 05, 2011 | DISH Network ViP722 DTV Receiver /...
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Jul 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
Cannot watch a different channel while recording another channel! What's up with that? We always get a message when we try to switch to another channel after setting up "record" for a particular program....
In order to do this with the 625 you must either place the receiver in single mode or change the Record Plus setting on the receiver.
To change to single mode you will need to pop open the small door on the right front of the receiver by gently pushing three to four inches from the right side of the receiver. Inside there will be multiple buttons press the one labeled mode. The blue light for TV2 will extinguish when it is in single mode and the amber mode light will switch from the duplex tile side to the single tile side.
The drawback to this is that the TV2 location now must watch the same program or something that was previously recorded on the DVR or utilize a peripheral such as an X-box or DVD player.
The other way results in the same outcome but to achieve this it will automatically default all recordings to be recorded at the TV2 location. Press menu on the TV1 remote then 8 - 5. You should now be at the Record Plus setting option. Use the arrow keys on the remote to manuever to the record preference setting and toggle up or down with the up down arrow keys to switch the preference to TV2. Now manuever to the activation option and toggle it to ENABLE in the same manner. Once comple select done and press the View Live TV button.
The reason you cannot watch and record at the same location and still have access to different programming at the second location is due to the receiver only having two tuners which means it only is capable of viewing two seprate programs at any given time. Once they both are in use by either TV1 or TV2 or both are watching independent programming the receiver is no longer able to access further tuners to display additional programs.
I could go into the technical aspects but it would not resolve the issue either. However if you desire this capability at both locations you can check into changing the receiver from a 625 to two 512's which will allow you the ability to so.
I hope this helps you out. Thanks for using Fix Ya and being a Dish Network customer.
Mar 30, 2010 | DISH Network DVR-625 DTV Receiver /...
Record tv with Panasonic DMR-E75V DVD Player / VCR
Not sure about this, but my guess would be that you don't have the correct channel set on the DVD recorder. It has to be the channel that you use to receive your signal, NOT the channel that you necessarily want to record. For instance- if you use channel 3 to receive your signal from dish, cable etc but want to record a program on (hypothetically) CBS which is (again hypothetically) channel 24 from your dish or cable provider you would go to "Prog/Check" on the remote, highlight the "New Timer Program" line and press "Enter", and then use the numeric buttons to select channel 3 (the channel you use to receive your signal, NOT 24, the channel you want to record). You will have to program your dish/cable box to provide the channel with the content you want to record, in this case- 24.
Not sure if that was your issue, but hope this helps.
Jun 15, 2008 | Panasonic DMR-E75V DVD Player/VCR
Watch while recording
Make sure the DVD has RF lead and Scart lead connected in and also BOTH connected out to the TV. When you record from TV use channel numbers, when you record from cable use AV channel, (on DVD). When watching TV use TV channels 1 to 5, when watching Cable use AV channel, (on TV).
Feb 06, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Tivo and direct tv
No, unfortunately there is not. That tivo only has 1 tuner, so you can only record or watch 1 live program. You can however watch a pre-recorded program while recording a live program. If you have directv, you can step up and get their hr20 dvr. It's not a tivo by any means, but it has 2 tuners so you can record 2 things at once and watch a pre-recorded show. It takes a little while to get used to the interface, but once you get the hang of it, it's pretty straightforward.
You can also get an older DVR w/ tivo (hr10) however, it will not get ANY of the new MPEG4 High Def channels that are out there.
If you have an hdtv, then you really should grab an hr20, give directv customer retention a call and ask what they can do for you. You'll need a new slimline dish and they'll come out install it and everything you need for watching off the new satellites and enjoying the new mpeg4 hd channels (the old hd channels are in mpeg2).
Good luck.
Dec 12, 2007 | Tivo Series 2 80-Hours Video Recorder
DISH Network 54 1 Ir Vip 622 722 Dvr Remote 222 Logo
192 people viewed this question
Top DISH Network Home Security Experts
Marvin
Marvin
Tom Chichester
Are you a DISH Network Home Security Expert? Answer questions, earn points and help others
