Samsung VP-D21i Mini DV Digital Camcorder Logo
A
Anonymous Posted on Jan 22, 2012
Vp-d21 windows 7 drivers - Samsung VP-D21i Mini DV Digital Camcorder
1 Related Answer
Anonymous
  • 10319 Answers
  • Posted on May 01, 2011
SOURCE: Have an computer with operativ
use this website to retreive your needed Samsung drivers
http://www.driversquad.com/driver.php?option=o&prodid=7356&cust=samsung+drivers_AD_www.google.com_&channel=&subid=201_US%2ADR_o&roia=%21iicYvq1BAAKLOkMAAAYOVQAAZT5CAABnCA-A
Is there drivers for windows 7 for the sitecom vp 003 webcam?
It as long time ago, but I have a solution for this challenge with Windows 10 (and Sitecom VP003 Webcam).
You have to use the mic' driver from original vp003 software package and the cam driver for HAMA Metal Pro Webcam (Driver 1.0, https://drivers.softpedia.com/get/SCANNER-Digital-CAMERA-WEBCAM/HAMA/HAMA-Metal-Pro-Webcam-Driver-10.shtml).
It works for me and I'm happy ;o)
Regards,
Gino
3answers
Hi my girl bought a Sitecom vp-001 Webcam and the driver is not working for windows 7 (told her it wont but she no listen XD) anyway can anyone tell me if there is a updated file that can support it for...
Although this camera is not compatible with Windows 7, I suggest to try this download link also (extract the zip file and run the setup file). In case of no luck again, before running the setup file, right click on it, go to properties and at the compatibility tab check the box for windows XP sp3 compatibility and hit apply - ok. Run the setup file as usual.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
I NEED THE DRIVER TO WINDOWS 7 MY CAMERA IS VU POINT MODEL DV-M5056-VP
You can download the driver from the manufacturer's web site at
ftp://vps:[email protected]/Drivers/DV-M5056-VP_Driver.zip
Can i connect my vp-361 direct to a usb port ?there is a cable where it need a special connection to the pc
Hi Willy, i have the same problem. Im trying to connect my Samsung VP-D361 Mini DV Digital Camcorder to my laptop (Windows 7) but I cant. Is the problem with the O.S driver compatibility?
I changed from xp to windows 7 and now my pc does not recognize my camera, perhaps i have to do something because I cannot import my videos from the camera to the pc, I have a mini dv samsung VP-D361...
If your camera has digital video output (firewire connection also called i-Link), you coud work with a generic driver from Windows 7, and also you can have a faster transfer speed using firewire.
I just installed Windows 7, they worked no problem before that. Now it claims I don't have them installed. I believe the problem is the drivers.
When you reloaded to windows seven you didnt load your sound card drivers figure out what card you have then go out to the web find the driver and download it
2helpful
2answers
Can someone tell me if the sitecom vp-003 webcam works with windows 7?? it kees telling me driver not found even after i installed it
yes it is, drivers are here http://www.downloadatoz.com/driver/download_87827,sitecom-vp-003-driver.html
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
I wont free download samsung camcoder vp d463i drivers
From here you can get all instructions and drivers..
http://www.easydriverpro.com/driver-update/camcorder/samsung/vp-d463i/vp-d463i-windows-7.html
If you like ma answer do rate me and a testimonial..
Thank You
2answers
Looking for the Vupoint Filmscanner driver. Thanks for helping..
Hi Thierryghi,
thanks for explaining in detail.
Please download the driver for your device from the below link.
ftp://vps:[email protected]/Drivers/FS-C1-VP.zip
But I am not sure whether it will be compatible from Windows 7.
Try installing the driver. If not installing on win 7, then right click on the setup.exe and select properties. There select compatibility to windows xp as something similar like below.
After installing the driver, you need to install software so that you can use that software to scan.
Please download the software from the below location and insatll this as well after installing the driver.
ftp://vps:[email protected]/software/PhotoImpression_6.1.8.130(new).zip
After installing this s/w you will be getting some shortcut in desktop using which you can scan your film.
I hope this will be useful to you.
Thanks
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
