Question about Toshiba Satellite A660 Series Notebook
Disabeled hdd and can't boot toshiba a660
Posted by amcharg on
Mark Zetts
    New Friend:
  • 22 Answers
You'll have to boot from a bootable CDROM.
Posted on Jan 23, 2012
My toshiba L745-s4235 laptop is shutting down randomly
Sounds like a failing hard drive or it has some bad sectors.
Oct 19, 2012 | Toshiba 14.0" L745-s4235 Satellite Led...
My Toshiba hard disk is not functioning well
Hi,Dear Customer,
1> Please check you HDD cable connector.
2> Where from connect HDD cable in mother board, this port change and be care fully connect.
3> Check HDD bad sector. If you hard disk create a bad sector then not well run any hard disk.
4> Check jumper setting, first boot & sec Boot option. you hard disk where connect first boot & sec Boot option.
I think solve you problem.
Sep 12, 2012 | Toshiba Computers & Internet
Laptop wont turn on, got green pwr and amb bat but will not fire up
Systems covered: All failing to boot without lighting up display.
Goal of this Solution: Try to determine whether system is (a) booting successfully while failing to light its display (indicating hardware failure in the display), or (b) failing to light the display due to failure to successfully transfer control to ROM BIOS (indicating a motherboard failure).
The fact that the Green power LED, and Amber Battery LED are lit seems to exonerate the laptop power supply (brick) circuitry. Even with a nearly dead battery, a Toshiba Satellite 1135-s1552 should work while plugged into a properly functioning brick.
Here's Toshiba support's (244 page) online PDF version of your laptop manual:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=434997&rpn=PS113U&modelFilter=1135-S1552&selCategory=2756709&selFamily=1073768663
If the HDD (hard disk) activity indicator LED is active after power-on, then your system has actually got past BIOS and is booting - your LCD monitor inverter circuit or Backlight may have burned out - and to use the system, you'll need to connect an external monitor to the RGB monitor port on the back of the system (see illustration on page 32 of User's Guide) to view system activity.
Alternatively, one may attach an analog TV, using the S-Video port on the back of the laptop (see illustration on page 32 of User's Guide).
Once an external monitor is working to display the ROM BIOS part of the boot sequence, you may find that the ROM BIOS is good enough to run a few BIOS-based diagnostics. Run them all - something may indicate the source of the boot failure. Ofttimes, enough of the motherboard remains good to provide interaction with the ROM BIOS, but some motherboard failure will subvert a full boot to Windows/Linux. An example of this type of failure would be a failure of the PCMCIA bus controller, which is vital for booting a disk-resident OS, but unaccessed (except by BIOS diags) when the user interacts with BIOS. Another common failure of this type is main memory (RAM) failure.
A working external monitor/TV also provides a chance to backup important laptop data to a flash drive, sky drive, or CD-RW discs.
If no HDD activity is seen after power-up, then either your BIOS is hosed (in which case you'll need a new motherboard), or another motherboard component is hosed (in which case you'll need a new motherboard).
You may want to transplant the HDD into a working PCMCIA-bus system (any laptop) to recover/backup your important data.
If someone recently attempted and failed to update the motherboard's ROM BIOS, then you know why the system is failing to boot and also failing to light the display.
Here's a link to a site with disassembly instructions for Toshiba laptops:
http://www.irisvista.com/
Most dead laptops (even those whose power supplies have been burned out by a nearby lightning strike with the system on 120 VAC power) will still have perfectly usable HDD module(s), and RAM memory cards, so that at the very least, these removable components may be recycled into memory reserves for your next laptop or sold (Ebay.com) to help defray the cost of a new system.
Dec 14, 2011 | Toshiba Satellite Computers & Internet
I just bought a Toshiba laptop A660 Series. It did not come with a user manual. Can you tell me where I can get one please?
Do you know the remaining letters on this model? it should read A660-xxxxx
go to this site belongs to Toshiba and find the user guide specific for your model!
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Product%20Support
type above address on you browser address bar and click go! you can copy and paste that's easier and more reliable as you may miss one of the letters and you may not get to the right address!
good luck
Sep 15, 2011 | Computers & Internet
Hi i was working on my TOSHIBA SATELLITE A660-13Q and it was freezing then after i restarted the machine it gave me a message saying that ( Your computer has recover from a fatal error check for solution...
Yep. U had a software issue initially - there was nada wrong with your bios. Apparently, the bios update did not go well and now you have a piece of junk on our hands. Without a proper working bios no computer will boot up. And on a laptop the bios chip is usu.ally soldered on the motherboard so it cannot be readily removed and replaced.
Time to go shopping.
Mar 11, 2017 | Toshiba Satellite A660 Series Notebook
Hi, i can'to use function key and media buttons (eco,wireless,shortcut,play/pause,minus,plus) ...because i don't have any installation drivers for them ...my laptop is toshiba satellite...
You may download all versions of drivers for your Toshiba Satellite A660 BT2G23 available thru this LINK.
I hope this works for you. Kindly reply/comment for further assistance. Good Luck!
Thanks for using Fixya!
Mongkey
DELL Tech ID #456563
TIPS: Is your computer slow? This might help
http://www.fixya.com/support/r8158906-diy_manual_pc_tune_up
(for Windows only)
Jul 08, 2011 | Toshiba Satellite A660-BT2G23 Customizable...
HOW DO YOU TURN LIGHT BENEATH KEYBOARD ON TOSHIBA A660/07T
I'm not sure what model you have I do not see a A660/07T.
Here is a listing of the different models that have an LED Backlit keyboard. http://us.toshiba.com/computers/laptops/satellite/A660/available-models?EXTRAS=LED+Backlit+Keyboard&SERIES=A660&SUBBRAND=Satellite%26reg%3B&Ns=pUnitsSold'1&sms_ss=email&at_xt=4cddcae4e07d677f,0
Mar 05, 2011 | Toshiba Satellite A100-S8111TD Notebook
I have a Toshiba Satellite A660 in front of me. It passes the Toshiba splash screen but won't boot into Windows. It's less than a couple of months old so if necessary will be going back to the reseller but...
Since the WARRANTY still is valid, the easiest route is to exercise the warranty.
Or, use the supplied "System Restore" set of CD-ROMs to reload Windows (this will wipe-out any data from your 'C:' disk-drive).
It might be possible to temporarily remove the disk-drive, connect it as a "slave" disk-drive in another computer, and then to copy all your files onto DVD-writable disk(s), before sending it in for warranty service.
Feb 21, 2011 | Toshiba Satellite A660 Series Notebook
Unable to boot system and repair feature will not run. Also, there are no restore points (files). However I can get into the cmd prompt mode. Safe mode does not work. System is a Toshiba Satellite...
Hi there!
Well it seems that you are in a bad situation my friend. So let me help you out.
It seems that your system files are corrupt & preventing it to go to windows (may be due to improper shut-down).
What to do?
Please remove the hard disk from your laptop, put it in an external 2.5" casing. Then plug it to another laptop or pc having a good anti-virus. Now switch on the other computer. The system will correct the files on boot. If this doesn't happen, go to my computer after boot. Locate the HDD in my computer \ your HDD \ properties \ tools \
Here you'll run chkdisk & scan for errors, bad sectors etc. After that scan for any virus in that HDD. Now back up your important stuffs & send it to your DATA partition.
Now shutdown laptop & remove the HDD from the casing, then put it back in your laptop. Now boot & see your problems solved.
Please send us your feedback & vote to motivate us.Thanks.
Feb 19, 2010 | Toshiba Satellite A215-S4747 Notebook
Toshiba Satellite A660 Series Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Michael Thomas
Michael Thomas
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
