SOURCE: ford focus car engine light coming on knocking
Go to Orielly auto parts and rent their OBD scanner. If you takethe vehicle to them they wont charge you for the scanner. The dealer will charge you $100 or more to check it for you. Depending on how loud the knock is I would not recomend driving the vehicle until you scan it. Once you scan it write down the codes and Oriellys can translate them for you also.
SOURCE: what does the orange engine light mean on ford focus 02 reg
It's a check engine light, have it checked right away. If you take it to a Ford dealer, they can give you a very detailed diagnosis, however they also charge about 80 bucks just to do that. If you take it to an auto parts store (AutoZone, Advance Auto Parts, NAPA, etc.) they will often be able to check for free, but it won't be the most detailed solution.
SOURCE: 2000 ford focus engine light on. what could be
Hi
1 is the car losing power?
2 is the car rough at idle? or slightly over reving.
If so most likely cause for 2 is the air mass sensor, this go's to the air box you can cleran them with carb cleaner and sometimes this will fix it.
Get back to me for more ingo.
Regards
Dan
SOURCE: 2006 ford focus reset engine light...
the only way is to connect with a ecu analyzer-programmer to a authorized or specialized service garage to find the cause and reset the ecu.
