Had an alarm with wireless stop/start. I've cut it out as we keep having problems with it, as well as everything else. has done a lot of beach riding before we were given it, lots of corrosion, etc in wiring & stuff. All I'm after is a wiring diagram, with or without alarm component. So I can figure out where to go from here. Pretty Please & Thank You.
SOURCE: Wiring Diagram For Orion 250sx
HERE is the info you're looking for.
Thanks for usnig FixYa - a FixYa rating is appreciated!!
SOURCE: KAWASAKI ZL 400 ELIMINATOR cutting out..then only sparting once
sounds like your cdi box is faulty
SOURCE: just bought xj650 yamaha motor for a buggy all wires are cut
Hi and welcome to FixYa,
For the wiring diagram of a Yamaha XJ650, pls click here.
Good luck and thank you for using FixYa.
SOURCE: theres alot of smoke coming out the exhaust pipe
Sounds like the crank case engine oil level is too high. Ovefilled, Two or 4 stroke?
SOURCE: my zx12r cuts out while riding them wont start
You should measure the fuel pump's supply first to check that the pump works ok.
When it dies, do you hear the pump pressing your ear against the fuel tank and turning the key to on position and your kill switch to on too?You should hear it working for 3 sec.If not working at all start by checking the pump's relay and then the pump itself.
