Trying to play 8mm tapes for converting to DVD... hear the tape advancing for about 3 seconds and then the error code D:31:22
SOURCE: error message 31:22 reinsert cassette tape
reel sensor is the problem of your camera it is a common problem to that model,maybe the pinch roller is loosen to the post cause of the lock of that is been broke..that roller is that one that pulling the tape...only a technician can put it back to the mechanism and replace that lock...in sony service they replace the whole assembly and cost a lots...i suggest find other service center for fixing it...hope that roller is not lost in your camera...
SOURCE: Sony Handycam Vision ccd-trv308
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
SOURCE: C 31
The camcorder has detected an issue that may require a power reset. To POWER reset the Camcorder,
SOURCE: Sony DCR-HC38 error C:31:22 re-insert tape.
Sony is a ******* piece of **** corporation that has foisted their name on professionals and consumers as being the epitome of high technology for all forms of media. They are, in fact, scam artists that have perfected the art of programmed obsolescence and early life failures for their equipment. Because I have been a professional video/audio engineer for 30 years, I have been forced to own and use more Sony gear than I am comfortable admitting to. There is NO answer to your dilemma because it is a defect programmed into the circuitry of Sony DV-Cams that will ultimately force you to take the machine in for repairs...again and again and again and again....
Do your self a huge favor and smash that piece of **** with a sledge hammer right now. Then, go out and buy a Canon. Great products and great tech support. Sorry I couldn't solve your problem for you. But, I am an engineer and I can't even solve this one myself.
