Try heating up touchpad with blowdryer , if that doesnt work replace touchpad.... On the smh9207st remove plastic cover from the back of the door . Remove 4 screws and 1 screw at the top of the door . Unplug two connectors Gently. ... Peel off front touchpad . Install is reverse of removal . Be safe .....part was $45 @ repairclinic.com
The instructions for disassembling the door are overly simplistic. The number of screws is correct, but taking the door apart was difficult as there is no obvious way to do it. Once disassembled, there was no way to get at the touchpad without removing the chrome facia on the front which seemed to be glued on, and prying would certainly destroy it. You cannot..."Peel off front touchpad..." UNLESS, these instructions refer to another micro, or there is a way to do it but William did not mention it.
correct, just a control board , pop off the inside trim on the door ,then unscrew 4 screws then pry out the inside door, the outer glass will come apart then you'll see the board
SOURCE: Our samsung microwave displays shows 5E and hangs
-SE- error means you
have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired,
please leave it unplugged or leave the door
open when it's not in use, and please do not leave it running
unattended.
It's usually more economical on a Samsung to replace the control panel assembly, which includes the frame and keypad or (depending on your model number) the entire control box assembly which includes the keypad, frame and circuit board.
Either parts swap is easy to do. About 8 screws and a few connectors.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Samsung Microwave Oven shows -SE- on the display. Why?
have a shorting membrane keypad.
Since
it's less than one year old, it would be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
You can find your
nearest Samsung-authorized service center here or call Samsung's Service Division at 800-932-3837.
We're
SOURCE: 5E error message
"SE" means you have a shorting membrane keypad.
If and when an oven
unattended.
On most Samsung models, your best bet is to buy a whole new control box and replace it.
This is a simple do-it-yourself job.
You can find
At
If you do not find information about your model or you need more help, note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
So please post a NEW question, and please
include your brand name and the full model number from the tag in or on
the unit
SOURCE: Microwave model UMC5200BAB display is
"SE" error means you
If you (or someone you
know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically
involved.
You can find
model number here.
If you would like to
have us
do this repair for you, we do that for $39.95 plus part costs
