Cars & Trucks Logo
Shailesh Patel Posted on Oct 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My radio, clock and internal light don't work
Hi all,
I've got a 1989 Toyota Corolla 1.6 GL Executive. A few days ago I replaced the stereo and now for some reason the radio, the standard digital clock and the internal light don't work. I had a look at the car manual and it told me that all these and the cigar lighter are on the same fuse. The strange thing is, I've checked the fuse and its fine and the cigar lighter is still working.
If anyone has any ideas what could be wrong please let me know.
Thanks in advance.
Sean
  • 2 more comments
  • Shailesh Patel Oct 17, 2008
    Thanks alot, I'll have a look over the weekend and revert on Monday.
    Sean
  • Shailesh Patel Oct 20, 2008
    Thanks for the push in the right direction,
    I had a look at the dome fuse on Saturday and it had burnt out, I've now replaced it and everything works fine again.
    Thanks again for the suggestion.
    Sean
  • gilliamnnn Dec 08, 2008
    My daughter has a 2002 corolla and the radio, clock and mirror light doesn't work. The fuse box is in the hood but can,t find the right fuse. I,ve tested them all and can,t seem to locate the problem. Is there another fuse box? Dale
  • Anonymous May 11, 2010
    Look for a burnt Dome fuse; please advise if you find it burnt.
Anonymous
Level 3:
  • Toyota Master 1,861 Answers
  • Posted on Oct 20, 2008
Anonymous
Toyota Master
Level 3:
Answers
1861
Questions
23
Helped
1483949
Points
8422
The graciousness of a FixYA would be much appreciated; glad to be of assistance.
My clock in the radio quit working a few days ago, does it need a light bulb replaced or a fuse?
If the clock is part of the radio, suspect an internal failure of the radio
I have a 1998 toyota corolla ve with electrical problems first it was the dome light the the dome,radio,clock, and cig lighter now its just the clock,radio, and cig lighter I checked all fuses they we
check the fuses again, sometimes they blow right after you install them.
there may be a short in the wiring causing them to pop.
check fuses again and let me know
I think I blew a fuse in my 2000 Toyota Corolla
find the fuse that says radio and replace it
5helpful
3answers
My 2003 toyota corlla clock is not displaying, but
Sorry. The clock, the dome light and the radio are on the same circuit. If the radio works, the clock is bad.
Radio light dims when I press the brakes
sounds like you might have a bad ground
1989 Toyota Corolla Red light next to clock
that may be the alternator indacater lite your alternator may be going out go have it check
1helpful
Hi , i have toyota corola 2006 model I have problem with dash bord clock light - bulb not working kindly advice what cani do thanks .. amer f
The fuse in postion 32 (15 Amp) in the box under the dash by the steering wheel also powers your cigarette lighter and radio also powers the clock. If only the clock is dead then it is not a fuse issue. This is a very common problem with the 96-05 Corolla clocks. The clocks are very prone to internal failure. I offer a reasonable repair service with a lifetime guarantee, check it out:
www.autoclockrepair.com
There is a bunch of useful info there. Drop me an email if you have questions, thanks!
7helpful
2answers
Request for the wiring diagram for a 1989 UK spec Toyota Corolla Hatchback
Sure. Glad to provide assistance.
89 Corolla radio wiring colours:
Power- Solid GREY -
from the 7.5 amp RADIO fuse
Backup power - BLUE w/YELLOW tracer
from the 10 amp DOME fuse
RF speaker - LIGHT GREEN and BLUE
LF speaker - PINK and VIOLET
RR speaker - RED and WHITE
LR speaker - BLACK and YELLOW
Ground/Earth - BROWN
The graciousness of a FixYa rating would be greatly appreciated.
3answers
Top Toyota Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Toyota Expert? Answer questions, earn points and help others
