Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Until Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, ``
SOURCE: I have a new Pope Renegade 26cc Line Trimmer.
Hi I have a Pope Renegade 26cc and had problems with the bump feed head so did some research and bought the Pivotrim from Amazon,and it works great and was easy to fit.You can see a video of the Pivotrim on Youtube.
SOURCE: REplacing the pulling cord on a gas trimmer
those are usaully under your pull start cover and if its broke you can buy a new rope but if its broke near handle i would open it and retie it to save ya money. but remember to wind spring a little to keep tension on it before pushing it through the hole for handle.
SOURCE: Weed Eater Straight Grass Trimmer, 25 CC, 17-in.
Some of the weedeater heads are known to be ineffective and quite troublesome. Try Home Depot maybe for a universal type head that will hold and feed line the way you want. They have strimmer parts.
which way to fit cord to spool
