Question about Metra Ford F 150 Truck 1996 Up
96 5.8 distributor plugin diagram
Where you plug the distributor in there are 8 color coded wires and i need to know which ones go to what cylinder
Posted by Cory Mitchell Metz on
1 Related Answer
Rob getz
  • 689 Answers
SOURCE: speaker wires behind radio cut, cant get any of them to worik. anybody know the color codes on the wires ford explorer 96
Go out to a auto wrecker and get enouther harrness for it,That is the easisy way to repair it,
Posted on Nov 05, 2012
Diagram spark plug wiring
my guess, is you removed them and didnt mark them?
the firing order?
what engine, there are 5.
to do this , one need to know 5 things.
2.5L, 2.8L, 4.0L and 5.2/5.9L engine displacements.
the distributor rotation direction CCW, or CW
and last the firing order, sometimes marked clearly on the intake manifold.
you must now where #1 cylinder is (always most front)
1989-98 2.5L Engine firing order: 1-3-4-2 Distributor rotation: Clockwise
2.8L Engine firing order: 1-2-3-4-5-6 Distributor rotation: Clockwise
4.0L Engine firing order: 1-5-3-6-2-4 Distributor rotation: Clockwise
5.2L and 5.9L Engine firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
on a v6/v8 one cylinder is more forward. this is #1, look carefully.
Nov 26, 2013 | 1997 Jeep Grand Cherokee
Spark plug wiring diagram for 05 tahoe
Greg Bernett 2821 Solutions February 14, 2010
You didn't post your engine size so please pick the applicable diagram:
1996-98 4.3L Engines Firing Order: 1-6-5-4-3-2Distributor Rotation: Clockwise
1996-98 5.0L, 5.7L and 7.4L Engines Firing Order: 1-8-4-3-6-5-7-2Distributor Rotation: Clockwise
4.3L Engines Firing order: 1-6-5-4-3-2 Distributor rotation: Clockwise
4.8L, 5.3L and 6.0L Engines Firing order: 1-8-7-2-6-5-4-3 Distributorless ignition system (one coil on each cylinder)
5.0L, 5.7L and 7.4L Engines Firing order: 1-8-4-3-6-5-7-2 Distributor rotation: Clockwise
Source: spark plug wiring diagram for 98 tahoe
    ledsled378 2926 Solutions July 24, 2010
01f93b7.jpg ..............................
Source: Need diagram for spark plug wiring for 1997 Chevy
Testimonial: "Thank you for your prompt response. Saved my husband from some distress!"
Was this solution helpful? Yes No
    Dennis Weid. 44272 Solutions September 16, 2008
This was all I could come with, hope it helps.
Feb 27, 2013 | 1998 Chevrolet Tahoe
I need a wiring diagram showing wiring from spark plugs to distributor for a 1994 ranger v6 3.0
Use the diagram below and just match up the colors of the cylinders to the distributor cap for proper firing order. So starting at the black dot on cap and moving to the right the next cylinder is 4 the 2 the 5 the 3 then 6.
Feb 17, 2011 | 1994 Ford Ranger Supercab
I took of*** my spark plug wires working on my small block 350 pickup and I don't remember the the firing order to put the new wires back on. Is there a diagram anywhere or is it even that difficult to...
Next time number each lead before you remove it and no. the dissy cap as well
The firing order, which should be cast into the intake manifold, for the chevy small block V8 is 1-8-4-3-6-5-7-2. The firing order is the numerical sequence in which the spark plugs are fired. The insertion position of each spark plug wire around the circumference of the distributor cap can be found according to a clock face. The insertion sequence determines the firing order. The firing order is followed clockwise around the distributor cap starting from the 6:30 position with the 6:30 position being the number one cylinder spark plug wire.
On classic chevy small block engines that use ignition breaker points instead of electronic ignitions, the number one cylinder is the one immediately clockwise of the small metal sash cover on the distributor cap. The firing order starts here. There is no sash cover on the distributor cap for GM HEI electronic ignitions, and the firing order is the same, but starting at the 5:30 position.
The firing order makes sense if you know how the cylinders are numbered. The number one cylinder is the front most on the drivers side and 2 being the front most on the passenger side. From front to back, the cylinders are odd numbered on the drivers side, and even numbered on the passenger side.
See the diagram; Click to open a printable larger image in a new window. The firing order starts with the number one cylinder. We would connect the number one spark plug wire to the distributor cap terminal in the 6:30 position. distributor.pngSince the next cylinder in the firing order is 8 (passenger side rear), we connect the number 8 spark plug wire to the next distributor cap terminal (approximately 7:30 position) in the clockwise direction from number one. You need to be sure you continue the firing order in the clockwise direction around the chevy small block distributor cap from the last installed spark plug wire. Setting the rest of the firing order is just a matter of repetition. Be sure to count the spark plugs from front to back on each side of the motor to identify the correct cylinder number in the firing order.
Jun 21, 2010 | Cars & Trucks
Spark plug wiring diagram for 98 tahoe car is missing need to know which wire goes were
Feb 14, 2010 | 1998 Chevrolet Tahoe
I need a print out of the spark plug wiring diagram
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway.
I'm not sure if you have the 2000 Dodge 1500 with the 3.9L (6-Cyl), 5.2L (8-Cyl), and 5.9L (8-Cyl) Engine; however I have included.
For the 3.9L (6-Cyl):
Firing Order:
1-6-5-4-3-2
Cylinders:
(back of engine)
6----------5
4----------3
2----------1
(front of engine)
Distributor:
(+).6...5
1...........4
...2....3..(+)-screw
For the 5.2L AND 5.9L:
Firing Order:
1-8-4-3-6-5-7-2
Cylinders:
(back of engine)
8...........7
6...........5
4...........3
2...........1
(front of engine)
Distributor:
.......(back)
.........3
....4........6..(+)
8...............5
(+)1........7
.........2
Again my apologies...
Let me know if this helped, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Jan 18, 2010 | 2005 Dodge Ram 1500
Two of the plug wires got switched and i dont know which ones. its a 99 durango slt with 5.2 liter. if i had a picture or diagram to tell me where each plug wire goes i could fix.
the firing order is 1-8-4-3-6-5-7-2 , distributor spins clockwise, so find number one on the distributor cap and then the next cylinder will be #8 and so on in a clockwise direction
Mar 18, 2009 | 1999 Dodge Durango
1987 GMC Jimmy Distributor cap and Rotor replacement
A diagram may not be needed as its a reasonably easy fix to do on your own.the distributor ca p will only fit on properly one way because at the base of the cap locaters can only fit the distributor if they line up.When doing the spark plug leads do them one at a time and if nessecary write or mark leads as 1,2 etc .The rotor can only fit on one way but put a mark on the distributor to show where the rotor was pointing when you took it off and if it still points there when the new one is fitted.When changing distributor cap and leads they have to go to the correct place.Pays to mark the outside of distributor cap where the locating bits are On the new and old one.Fit the new cap and rotor then take a spark plug lead and fit to new cap 1 at a time.You can tell by lining up the marks on the outside of the distributor cap when you hold them one on top of the other.Good luck
Oct 20, 2008 | 1987 GMC Jimmy
1995 Ford F350 5spd. distributor cap wiring diagram/layout!!!
1) #1-4 pass side front to rear #5-8 drivers side front to rear
2) 1-3-7-2-6-5-4-8
3)#1 is usually marked on cap wires go ccw
4) TDC #1 cyl you must remove the shorting plug before timing
it is located by the dist plug or the ignition module small gray plug
Jul 17, 2008 | 1995 Ford F350
Metra Ford F 150 Truck 1996 Up Logo
Top Metra Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
jdthefixer
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
