The DVD/CD drive won't open. It's hid behind a face plate and when I push the tab, it clicks but won't open. On one forum site someone said that the computer thought it was reading a disk and I should unclick autoplay. I did this but it still doesn't open.
SOURCE: My ASUS computer will not read my SONY memory
You need to go to Device manager, remove ALL USB devices the whole thing.. remove and uninstall driver. then, reboot. Now at next desktop, try using the USB stick then, this often "Fixes" any problems. (Windows will auto-install the entire USB layer all again at boot up)
SOURCE: how do I open the
at the bottom on the right of the top panel dvd drive there are words the words stating to push with a arrow under the words and gently push on it and the dvd door will open and a carriage with slide out excessing a spot to place your dvd or cd disk; gently push it back and wait a second or two and auto play with ask you what u want to do.
If you are referring to using the program; click on my computer
there should be icons with main drive(C) and another DVD Drive
just click on that icon and the program should open for your decisions to
use or modify
SOURCE: How to install a ASUS CB-5216A 52x CD-RW Burner DVD-ROM
Here is a site that has a good manual for installing the Dvd Burner. It is very stright forward once you open up the case. Just make sure that you unplug the computers power cable, open up the case. Notice how the cables in the back of the cd rom are connected. Take the CD rom out and slide the new one in. The site listed below also has pictures to help you out.
http://www.helpwithpcs.com/upgrading/installing_cd_recorder.htm
