Cameras Logo
Question about Kodak Cameras
Kodack easy share cx7330
User manual
Posted by grant hinden on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Kodak Master
  • 102,366 Answers
5 Related Answers
Anonymous
  • 2712 Answers
SOURCE: How do I download the
You can find the manual here:
http://www.kodak.com/global/en/service/
publications/urg00506toc.jhtml
Just print the pages you require or read it online, as it is quite exhaustive...
Posted on Apr 17, 2008
Anonymous
SOURCE: About battery door broken in Kodak CX7330
I purchased a replacement door from U.S. Camera for a total of $16.20 (this includes shipping). I just need to know how to take the old cover off and put the new one on. My other option is to take it to a local camera shop and have them change the covers for me.
Posted on Jul 27, 2008
Anonymous
  • 6487 Answers
SOURCE: need user manual for Kodak
This is the link where you can download the user manual for this unit http://wwwpl.kodak.com/global/plugins/acrobat/en/service/manuals/urg00731/Z1275_Z1285_XUG_GLB_en.pdf
Hope that helps...........
Posted on Sep 23, 2008
Anonymous
SOURCE: Kodack Easy Share 1033 camera
Kodak Easyshare C160 digital. How do you set the time and date?
Posted on Sep 07, 2009
leepania
Pania Lee
  • 1099 Answers
SOURCE: Kodak Easy Share CX7330 turns on momentarily, does
Pls. use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
Pls test with an alt. batt. Make sure that you are installing a fresh/ full charge battery
Remove the battery
Clean the metal contacts on the battery using a clean cloth
This camera is no longer repaired. But KODAK offeres a Trade up. Where you for the exchange of your old cam can buy a new mmodel for 25-30% cheaper than market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Posted on Nov 11, 2009
User manual kodack easy share cx7330 digital camera
You may view/download the User's Guide here.
Jan 21, 2012 • Cameras
Just bought a sandisk 16gb sdhc card for my kodack easy share digital camera and the card will not format
You didn't tell us the make and model of the camera. Not all cameras, especially older ones, can use SDHC cards.
Sep 16, 2011 • Cameras
My kodack easy share c183 camera will not charge
The C182 isn't a battery charger. It uses standard AA batteries, disposable or rechargeable. If you use rechargeable batteries, you must charge them outside the camera using a standard battery charger.
MY CAMERA KODAK EASY SHARE CX7330 IS STUCK ON DATE TIME HOW DO I GET THIS OFF????
I had the same problem.Use the easyshare software and connect to the usb of computer.This is a solution but the switch on the camera (OK SWITCH) is bad.
5helpful
4answers
I've got 16 of these cameras and had to replace the door on 3 of them. (I'm a teacher)
it is quite simple, but there are little tiny screws and some dexterity required!
to replace the battery door, you need a super small screwdriver (I've used both an eyeglass size and the screwdriver that came with my son's tech deck!) . you'll have to unscrew all of the small screws that hold on the back of the camera. remember which screws go to which hole - because some are longer than others. once the screws are out, you'll have to gently pry off the cover. carefully - you dont want to crack the camera case. you'll also want to be careful not to touch the sensor, which will be exposed with the case off.
NEXT you;ll have to pry the little spring out of the battery door to actually remove the old door. you'll probably have to use a screw driver to pull the spring on the new door back enough to fit back into the holes. that's really all there is to it. replace the cover and the screws.
Kodak easy share cx7330
I have the very same problems as listed above. My friends have different models of the Digital Cameras and none have these problems like the CX7330.
I need a new battery door do you know where I can purchase this item?
Try ebay. They have it all. You might be able to find a camera that doesn't work but is being sold for parts. I see stuff like that on there all the time.
Please help
non scarica le foto della memoria interna
Top Kodak Cameras Experts
David Shaub
Marvin
Marvin
Are you a Kodak Camera Expert? Answer questions, earn points and help others
