You have worn dogs and they need to be replaced,remove the top of the agitator where you put the fabric softener,just pull it up,then pull up the cover and remove the 7/16 inch screw and sepatate the agitator,you can pull the whole agitator out of the washer and work on it and then replace the dogs,go here and you can see the parts and price http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Washer-Parts/Model-LSQ9549LW3/1198/0153200/W0312163/00003?blt=06&prst=&shdMod= and watch this video on how to change them out,hope this helps and GO PATRIOTSyou want the agitator cam kit part number 285809 and it's around 15 dollars. http://www.youtube.com/watch?v=0GQh8JLqVv8
SOURCE: Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
SOURCE: Washer won't agitate
I saw this happen once and you know what it was? A loose connection!. I pushed in the timer's molex block and it worked! It musta vibrated out the socket somehow. You must flip up the console to access the controls.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: no agitation
I have a Whirlpool Utlimate Care II LSQ8520JQ0. For those having a problem separating the upper and lower agitator halves, here's how I solved it after about 2 hrs of aggravation.
Called Sears and Whirlpool with no help (didn't have tech manual...go figure).
I saw the same post with the problem with melted hooks (I called them tabs) ontop of the dog housing being melted. You can differentiate the melted tabs from the dog housing as the dog housing is usually clear plastic (after wiping all the crud off) and the tabs are white as they are part of the agitator. There will be four white tabs on top of the dog housing. They look both smashed and melted. I took a flat head screw driver and and hammer and chipped off the white melted tabs visible on top. I inevitably also chipped some of the dog housing but only marginally. Once chipped off you'll see the tabs are actually rectangular in shape. At this point I EASILY pulled the top and lower halves apart. Those retangular tabs are the molded part of the agitator housing extending down past the dog housing. You're home free at this point.
It's the melted tabs on top of the dog housing that keeps you from separating the halves. What a pain but finally figured it out.
SOURCE: agitator no spine
They are called "dogs" Part Number #80040 you can replace them yourself pick up the part at a local parts place.. the main cause of failure is due to overloading the unit..
This should FIX Ya
SOURCE: Whirlpool topload filss, will not agitate, spin or drain.
This sounds like you need a new motor coupling and an agitator repair kit on this unit. We have parts and will be happy to assist you with your repair.
When you purchase your parts through us, we provide part removal/installation instructions.
You may contact us at:
WWW.Accurate-Appliance-Service.com
We look forward to working with you and hope this gets your washer in good working order again.
Have a great evening, Ella
