SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom
button, the lens pushed out again and the camera worked normally for
that time. I had to go through that procedure every time I turned the
camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
SOURCE: Fuji Finepix Z1 Zoom Error
hey
i had the same problem with my z1 camera aswell
and it got really frustrating so i tried different things, like turning it off and on again, taking the battery out etc
but i think ive found the solution to this problem,
when you turn it on you get the zoom error grrr
what i did was open the slide and as the camera is turning on hold down the 'take picture' button at the top and the camera is like normal
it worked for me anyway
hope it works
SOURCE: Fuji FinePix S7000 Digital... Problem: Zoom Error
Fuji FinePix S7000 Didital Problem:Zoom Error
SOURCE: Fuji FinePix F40fd-Zoom error
Unfortunately this is one of the hardest cameras I have come across to repair. The plastic guide lugs inside the lens which keep it stable are so small that once they get damaged they are virtually impossible to repair and only a replacement part seems to rectify the problem. Source a donor camera on ebay for a cheaper option than sending to fuji. F45fd and F47fd use the same lens so these are an option for a donor if F40fd is not available.
SOURCE: camera showing zoom error
Try the "reset" option in the menu on the camera...it fixed mine...I was having a focus problem in macro.
seax
