How can I do a Factory Default Reset on a Kyocera FS-1028 MFP? I can't access the device throught the Command Center Web link or throught the control panel.
SOURCE: Kyocera Mita KM-2530 Laser Printer will only print the first page not the rest.
Log into your pc as admin and under the driver properties change from kpdl to pcl5
Its a combo of a problem with adobe reader and the KPDL driver
SOURCE: Kyocera Mita FS-1030D Laser Bottom 2 lights blinking.
I think the two lights flashing together indicates waste toner box missing or full but as this printer doesn't have a waste bottle I assume it means the processing unit (ie the drum bit) needs replacing.
SOURCE: Kyocera Mita FS-3800
hello helpless try to clean the printer from smeared tonner and the transfer. the grey print could be as a result of printing using application sofware. make sure the tonner economy mode is not active form the application software,if it was turn it off and save, then reprint.
I was able to get into the control panel on the console but I don't know how to do a factory default reset on this FS-1028 MFP. Nor can I access the Command Center from the IE brower. Is there a key combination that would set this thing back to factory settings?
