Samsung N150 (36725723009) Netbook Logo
Posted on Jan 21, 2012
Samsung labtop cursor jumps around when typing causing all kinds of problems including highlighting and erasing entire lines or sentences!
Frustrating typing problem... touchpad sensitive and cursor keeps moving around in middle of typing..help!!! this is awful and delays working
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 05, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2162
Points
Press Fn & F10. This disables the touchpad. You will have to use arrows or a mouse to move the cursor. This helps when you are doing a lot of typing. Press the same keys to enable the touchpad when you are finished typing.
3 Related Answers
Anonymous
  • Posted on Dec 27, 2010
SOURCE: hello, my samsung n150plus's cursor
I had the same problem and discovered that when I was typing my thumbs where touching the touch pad and that was causing the problem. I now type with my thumbs up and not touching the pad. I hope this helps.
bob chang
  • 226 Answers
  • Posted on Sep 08, 2011
SOURCE: while I type I lose
When you type, your thumbs have a tendency of touching the touchpad, those touches are probably treated as "taps" and consequently, the cursor gets repositioned and all of a sudden, you find yourself typing on a different line. It's incredibly annoying.
See if you can go into your computer's Control Panel. Go to Mouse and look for something that allows you to adjust your touchpad's tap sensitivity - you want to make it less sensitive (i.e. something that takes a real tap to register as a tap, cause right now, any glancing blow, or touch, is treated as a tap).
That oughta do it.
Anonymous
  • 5 Answers
  • Posted on Mar 07, 2012
SOURCE: Touchpad too sensitive - keeps moving cursor
You can try to use external/wireless keyboards, or change your sitting posture.
Jumping cursor
Keep your hands away from the mouse pad when typing on the keyboard.
Cursor keeps jumping
I suggest that you scan your computer with RadarSync so that you can find the latest touchpad driver update for your computer. It's a driver related issue.
David
Cursor jump while typing
It's the touchpad driver that's causing it. I suggest that you update the driver. You can search for the driver manually or use RadarSync to save your time.
David
My dell latitude labtop cursor jumps all over the screen
If this problem occur windows update you can try restore your operating system on previous date of windows update.
1helpful
I have an Acer laptop. While typing the cursor suddenly jumps up a couple of lines, or suddenly may highlight a phrase, causing instant erasure of the previously typed material. Why does cursor continually...
your palm might be hitting the touchpad causing your mouse cursor to move and jump around... try to type with only your fingers hitting the keys and the back of your hand raised and not hitting any part of your laptop... hope this helps....
4helpful
Jumping cursor on EEE pc.
You're hitting the touchpad with your palms as you type. Either lift your hands when you're typing or temporarily disable the touchpad.
2answers
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
Over sensitive touch pad, causes cursor to jump all over the LCD
Try control panel and double click the mouse icon then settings you can adjust sensitivity there
5helpful
2answers
While typing an email the cursor will jump back a few sentences
I recently acquired this problem after having my computer serviced. I have been using it for over a year with no difficulty. I read somewhere that this is a microsoft problem, one of their service packages. The question is, which one?
2helpful
Typing problem
the problem is where the mouse cursor is. When you begin to type have the mouse cursor as far down the page as possible the glide pad can pick up the slightest variant of pressure and move your text to the position where the mouse cursor is.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
