Question about General Electric Adora GHDA670N Built-in Dishwasher
How do i turn off my GE quietpower 3 dishwasher once i have turn it on? i pend the door, the lights are going on and it beeps periodically. help...
5 Related Answers
Anonymous
SOURCE: GE Adora QuietPower II Replacement Rack Wheels?
I HAVE A GE ADORA QUIETPOWER II. WHEN THE DOOR IS CLOSED THE BEEP IS SOUNDED INDICATIN THAT THE DOOR IS CLOSED BUT WHEN I PUSH THE START RESET BUTTON NOTHING HAPPENS. PLEASE HELP
Posted on Nov 28, 2008
Anonymous
  • 62 Answers
SOURCE: no water in dishwasher
check the water valve it could be bad and not be letting water into the unit...let me know and I will further assist you.
Posted on May 13, 2009
Anonymous
  • 18 Answers
SOURCE: GE triton II dishwasher normal light flashes and beep sounds
Ran across this today. Ge dishwasher normal light just blinks and beeps when latch is locked. I had to replace the control module and it repaired issues right away. Hope this helps
Posted on Nov 21, 2009
Anonymous
  • 83 Answers
SOURCE: How do I turn off my GE QuietPower3 dishwasher
If you just want to shut it off, press the cancel button twice--If you press it once it will drain before shutting off
Posted on Sep 17, 2010
Linda Price
  • 244 Answers
SOURCE: i have a ge quietpower 3 dishwasher. Lately it
Make sure your water temperature is hot enough to dissolve the soap. Generally, the water temp. should be 140 degrees. Run some hot water at the tap before you turn on the dishwasher. This will assure that hot water is in the dishwasher as soon as you start it. Be certain that there aren't any large pieces in front of the dispenser tray. Sometimes casserole dishes, frying pans or baking pans can block the door and prevent it from opening.
Also, the sprayer arms might be clogged with bone fragments, peelings, bits of paper, etc. If this is the case, you'll need to remove the sprayer arm, flush and then check the jets. If you see "stuff" in the jets, they can be remove with tweezers.
Finally, make sure the upper sprayer arm hose is securely seated with the tube in the back of the dishwasher that carries the water up to the sprayer arm hose. If these two are not seated correctly, the water will not travel into the sprayer arm hose, the sprayer arm will not turn and your dishes will not get clean! I hope this helps. If it does, please come back to Fixya and rate my advice.
Posted on Jun 10, 2011
My office's GE QuietPower 3 dishwasher detergent
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jul 29, 2011 | Maytag Dishwasher
GE Quietpower 3 Dishwasher does not stop running when door is open. I'm really tired of getting splashed in the face because I forgot a plate. *head desk*
Haha. Sorry but happened to me once. The door switch has gone bad. Get a new door switch and you'll be fine.
Jan 31, 2010 | Dishwashers
My GE Quietpower 3 has blinking lights, goes through a short cycle and shuts off. How can I either reset or fix? I've already flipped the breakers.
To re- set can take up to 90 second's depending on the cycle, the door has to remain locked or it will not re-set. Our's had not been installed correctly, it had to be closed very hard to get it to lock, it was doing the same thing as your's. Hope this help's. That beeping is annpying.
Aug 13, 2009 | General Electric Adora GHDA670N Built-in...
GE QuietPower 2 has three lights flashing, and won't work
Its the reset cycle... give it a few minutes, and it will be ready to go..
Apr 20, 2009 | Dishwashers
QuietPower 3, water seeps into unit,fills the base once per week.
I need more info but I would check the drain connection under the sink to make sure that it goes up after leaving drain , to keep the sink from draining into the dishwasher.
Dec 14, 2008 | GE 24 in. Profile PDW7800 Built-in...
Model number is on a sticker on the left wall of the dishwasher, just behind the door, about mid tub level. Post your full model number and I'll list your part number(s) for you.
Sep 06, 2008 | GE Adora GHDA656LSS Stainless Steel...
General Electric Adora GHDA670N Built-in Dishwasher Logo
239 people viewed this question
Top GE Dishwashers Experts
Mike
Nathan Van Boven
Nathan Van Boven
Bill Johnson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
