Open sixth string buzzing, still yet but less as I work up the neck. Is it a problem at the bridge? I sent the first one back because it's 5th string was doing the same thing. Might it be the new strings? I don't want to wait too long and not be able to sent it back if it is unresolvable.
SOURCE: strings are very far away from the last frets on the neck...
Sometimes the truss rod (nut you are referring to) will do the trick. The truss rod runs under the fingerboard and allows you to give the neck relief or tension. Some truss rods are dual action but I'm guessing yours is designed simply to give basic relief of the neck. I would make sure the truss rod is adjusted properly before sanding down the saddle. If you sight down the neck you should be able to see the relief in the neck - just use the string as your straight-edge. Most guitars need a slight amount of relief but higher-end guitars can be almost straight (better fretwork.) Once the neck has been adjusted correctly you can move forward with the setup.
Make sure the nut is also the proper height. If the nut is too low (1mm height between bottom of string and first fret) you should get it replaced by someone capable of doing such a thing. If the nut height is okay I would suggest moving forward cautiously by sanding the bottom of the saddle. Make sure this is done patiently and carefully as it can drastically change the sound and playability of the guitar. Hardly any material needs to be taken off to lower the action just a little. Error on the side of not-enough than too much. Make sure the bottom of the saddle remains flat! If the bottom isn't flat the guitar can sound horrible and if there is an undersaddle pickup it might not pick up evenly. The easiest way to do so is to tape some sandpaper rough side up on a flat surface (just don't pick something like mom's heirloom or something important in case it gets scratched.
If you'd like more detail check out http://www.fretnotguitarrepair.com/Repairs2.htm
Good Luck!
SOURCE: Guitar strings on a mandolin.
By now you may have solved this problem, but maybe this information is still helpful:
What you are essentially recreating is a tenor guitar. Many companies make tenor guitar strings. I would suggest D'Addario J66 80/20 Bronze Tenor Guitar Strings (10-32). I've done this a few times and it is quite fun and makes for an interesting travel guitar.
Have a blast!
SOURCE: change the strings on a
http://www.youtube.com/watch?v=A_q2wleWRvw
Thats a youtube video to help you out man, I bought 2 mavericks and 3 ibanez before I knew how to change the strings!
SOURCE: My Dean bass' strings rattle when i play and i
These often use a special Allen wrench. It is easy to damage the neck.
I would recommend taking it to a guitar place/shop and have them evaluate that the neck is the problem. There are other problems such as the bridge that can cause this.
SOURCE: buzzing of strings in frets up to fifth fret
For your buzzing problem you could try bowing the neck to see if that helps.
Testimonial: "I don't know how to adjust the neck so I'm leaving it up to a pro, but I think this is exactly what needs to be done. Thanks for the imput"
