Washing Machines Logo
My bosch wok 2001 washing machine will not do anything, comes up with 07 in window, all lights flashing, was working fine till today. i've cleaned out the filter thing too.
Posted by sharon bone on
Anonymous
If 07 fault is displayed that means carbon brushes on commutator are worn out and need to be replaced,
Posted on Mar 26, 2013
5 Related Answers
Anonymous
SOURCE: instructions on how to use bosch wff 2001 washing machine
hi if you look on the main bosch web site you can find a list of manuels for bosch washing macine witch are free to down load in pdf format hope this helps tim automan.
Posted on May 23, 2009
Anonymous
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
Anonymous
SOURCE: How to clean lint filter
when the machin is washing i got a light READY .constant not flushing light. what`s the problem ?
Posted on Oct 30, 2010
Anonymous
SOURCE: Bosch Maxx 5 Washing machine will not wash, drum does not spin.
maxx5, error F63
Posted on Dec 14, 2010
Anonymous
  • 436 Answers
SOURCE: Key is flashing all the
If its showing a key symbol then the child lock is on.Press and hold the start/pause button in for several seconds and this should take the child lock off and start to work again.
Posted on Jun 02, 2011
1helpful
I've just changed the brushes on my Bosch washing machine motor, but it's still not turning the drum! Is there anything else i need to reset?
1) Test the lid switch must be closed very well, this will NOT start the machine.
2) the start button test for open
3) tight any wires connector
4) see the outlet box from your house is o.k reset the breaker.
5) put some desklamp for to see if working, so go and test the power cord .
6) tight the fuse or c.breaker from control board.
6a) put correct tension in the belt, see for any obstruction mechanical with the clutch and brake see the diagram
7) try it
Hello I've got a Bosch classic 1200 wfo246 washing
Bosch classic 1200 wfo246 This video will show you how to change the pump washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
I have a Bosch she4ap06uc/05 quick wash light flashes. I have tried to reset it and it will not reset. The sump pump work and drains all the water out of the machine. It turns off and on fine but when...
Bosch she4ap06uc/05 This video will show you how to find the fault on a Washing Machine that Won't Drain or empty the water away on Bosch
Nov 13, 2011 • Dishwashers
13helpful
2answers
Key is flashing all the time. Its completely locked me out. It won't let me do anything. I've tried switching it on and off again like you do with computers to no avail. Please help. My machine is...
5helpful
2answers
It won't drain and says F4 on display, I have checked the filter at the front and it is clear, it is plumed in into the sink and that is not blocked? Pls help I can't afford a new washing machine...
That fault code is to do with the drain pump either its jammed or not working remove the front plate at the bottom of the machine undue the filter and check to see if it is either a blockage or something jammed in the pump.
Hope helps.
Washing machine, Bosch WOK 2401 Doesn't wordk 3 lamps are flashing: wassen , spoelen , centrifugeren/pompen. (wash,rins, pump?)
Washing machine, Bosch WOK 2401 This video will show you how to change the pump washing machine
Bosch WF2001 washes only 30 degrees programmes
We had this problem and it turned out in our case that the hot water inlet filter was blocked. The pump wasn't receiving any hot water into the machine so wouldn't start on anything except a cold (30degree) wash.
We turned off the the hot water tap on the plumbing at the back, disconnected the inlet pipe from the machine, then put the end of the pipe in a bucket and turned the water back on, and saw loads of sediment spurted out.
We ran it until we'd filled the bucket, then turned the tap off, emptied the bucket down the drain, then disconnected the hose from the plumbing and cleaned the hose separately (there's a gauze at the plumbing end of the hose so make sure that's clean).
Then get some pliers and where the hose attatches to the machine there's a filter that you can pull out. Clean this out. In our case this was completely blocked with limescale sediment etc.
Reconnect everything, check it's all tightly fastened etc. then turn the tap on the plumbing back on - turn it on to a hot wash, press start ...and in our case it all worked a dream again.
All this info is in the manual if you've got one, but I thought I'd write it out in case you've got this problem and don't have the manual.
Ahhhhh... cleeean washing again! Hope this works for you. Happy go laundry!
2answers
Bosch wok 2001
fill the whole system with hot water and add a bottle or two of mr muscle lime scale remover, leave to soak then drain via the bottom
33helpful
2answers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Open Questions:
0answers
LE and E6 Error Codes on LG Top-Loader I got an LE error code on my LG top-loading washer model #WT5070CW. Tried to reset it a couple of times, but it kept coming back. I understand that this code indicates that the motor is locked because the load is too heavy or any one of a number of other possible reasons related to the motor, rotor, etc.. I emptied the load and the error kept coming back, so I ruled out the load size as an issue. I turned the unit on it's side removed/inspected the rotor, which looked fine. I noticed the three screws that attach the Brake Actuator to the Drive Shaft and Shifter Assembly had somehow come loose, fell out and went missing, and the plastic Brake Actuator part had been cracked. I assume this was the cause of the error, and replaced this part with a new one. I also needed to secure this part with some larger screws, since the originally sized screws had worn out the threads where they were screwed in. I also looked over the wiring and didn't see any damage or wear. Next, I removed the stator and replaced the hall sensor with a new one just in case there may have been an issue with that part. However, when I reassembled everything and tested the washer, the drum still doesn't start to spin, and after a few moments, I get the LE code. Finally, I also changed the Washer Shifter / Coupling part, since I thought it may have been a little worn, in the hopes that that would solve the issue. When I restarted the machine, I then got an E6 error code. (Now, I'm not sure if I'm even past the LE error, or whether I have two errors at the same time.) I see the guidance online recommends looking for paper clips or coins stuck inside the washer tub, but there's definitely nothing like that. I'm reluctant to order more new parts as may be recommended in line with this error (clutch, drive shaft, etc.), and would welcome any guidance or suggestions on all of this. I've also been "agitating" my significant other by caving in to her wishes and calling a technician or ordering a new washer. Any suggestions as to what else I should be looking out for, which may be causing this issue, and anything else I can do to troubleshoot this issue? Thx in advance.
Top Washing Machines Experts
Marvin
Marvin
john h
