Power company turned power off for 30 minutes and now cash register will not work. It turns on but that is all. No keys make anything happen
Well, I will take a shot at this one. Look around the back of the Register case for a reset opening. It may be a small hole in the plastic case that looks like a paper clip would fit in it. These Electronics usually have a Bootup button somewhere in the chassis. Then stick a pin or toothpick into this fixture to reset it.
If no luck, go to your Browser and enter the Make and Model of your unit. You may be able to find a Manual.
SOURCE: how to fix
hi JPOWER,
my problem in finding a solution to this problem is the fact that Casio doesn't allow anyone who isn't a Casio supplier to download the manual for the CE 3700.
I would firstly suggest that you cycle the power on the machine if you've not tried that already. To do this you need to power down the machine and physically remove it from its power source. Keep it powered down like this for 30s to 1min to allow the machine's memory to clear. Power it back up and try logging in now.
If this doesn't work and you still have the manual for the CE 3700, try looking up some section in it relating to the procedure to restore the machine to its factory settings. With the machine restored to its factory settings you'll be able to log into the machine as if you just bought it, with the down side of losing all the data acquired by the machine before the restore to factory settings was performed.
If this doesn't work either the possibility of physical damage to a electrical component of the register should be considered and could be verified by a electrical technician.
Hope you find this information helpful in solving the problem with your cash register and thanks for using the FixYa service
Kind regards
SOURCE: XE-A102 cash register
Hi. You have set the register to program mode. Turn the key back to Z/PGM, then press SUBTOTAL (you might have to press it twice).
It may print a list. This is normal. Then turn back to reg mode, and you should be back in business.
Mark
SOURCE: CASH REGISTER CASIO CE 3115 DISPLAY E 03 AND ALARM
This ino might help: Cleaning ERRORS: ______________________________
1.- Turn the Mode lock to OFF
2.- Press down the RECEIPT FEED button
3.- Turn the key to PROGRAM
4.- Lift up RECEIPT FEED button (FFFFFFFFFF)
appears on the display panel
5.- Press SUBTOTAL (wait for receipt to issue)
6.- Turn Mode Switch back to REG and use as Normal.
Also another bit goes like this:
RESET: _______________________________________
1.- Insert the OW key and turn to OFF
2.- Hold down the JOURNAL FEED button and turn the key to PROGRAM mode
3.- Release the JOURNAL FEED button. The display should shows "00000000".
4.- Turn the key to OFF
5.- Turn to REG1. The display shows "INIT" and "0.00"
6.-
Press the number 10801 and then press SUBTOTAL. Initialisation is
completed when the printer stops operation. The display shows: "_ 0.00"
Hope this helps in restting to factory settings................................sodeep
SOURCE: Casio TE 2000 Electronic Cash Register doesn't work.
u mean no power at all?
If yes, try to reset it. (NOTE: This method will RESET all of ur programmed data!)
1. Off power
2. Take out the AA size backup battery
3. On Power
4. The machine should show "0000000000"
5. Fix the AA battery in
6. Program the Date & Time
7. Ok
SOURCE: sharp cash register displays error message E3.2
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
You need to logon as there is no operator assigned to it.
Press 1 then press CLK# or CASH# button.
-WN
