This was really tricky.
There are two holes on the top, close together.
Slide
the thin loop through the hole closest to the side of the camera, and
then stick a pin through the other hole and try to 'fish' it out. You
can tell when you've hooked it because you can pull the needle by
pulling the strap. Once it's hooked, you have to carefully pull the
needle out, keeping the strap from sliding off by angling the needle
away from the other hole. Good luck. Took me quite a few tries.
Posted on Dec 25, 2012
Slide
Before you stick the end of the wrist-strap in the loop get a bobbypin and put it between the two sides of the ropes separating each side. then you try and slide it through and pull really hard with the bobbypin then as if just by magic you have your wrist-strap.
(DO NOT FORGET TO MAKE A KNOT AT THE END AND TIGHTEN IT)
Posted on May 24, 2013
SOURCE: Where can I find a user manual for my Vivitar DVR
You can download the manual at
http://vivitar.com/files_products/28/DVR_810HD_Camera_Manual.pdf
Posted on Dec 28, 2010
SOURCE: will an SDHC 4 G card work in my Vivitar DVR 805
how do you charge it
Posted on Dec 30, 2010
SOURCE: I BOUGHT A VIVITAR DVR
You can download the manual from the manufacturer's web site at
http://www.vivitar.com/files_products/28/DVR_810HD_Camera_Manual.pdf
Posted on Mar 19, 2011
SOURCE: I can't find an owners manual for a Vivitar
http://www.vivitar.com/files_products/625/DVR_805HD_Camera_Manual.pdf
Posted on Oct 29, 2011
Jan 21, 2016 | Vivitar Video Cameras
Dec 26, 2014 | Vivitar Video Cameras
Dec 24, 2013 | Video Cameras
Feb 08, 2012 | Vivitar DVR Video Cameras
May 27, 2011 | Vivitar ViviCam 5022 Digital Camera
Mar 23, 2011 | Vivitar Cameras
Feb 16, 2011 | Vivitar DVR 508HD Digital Video Recorder
Dec 16, 2010 | Vivitar DVR 508 HD Camcorder
Jun 01, 2010 | Vivitar DVR 810HD Flash Media Camcorder
Apr 26, 2017 | Vivitar Video Cameras
Dec 25, 2016 | Vivitar DVR Video Cameras
597 people viewed this question
This was really tricky. There are two holes on the top, close together. Slide the thin loop through the hole closest to the side of the camera, and then stick a pin through the other hole and try to 'fish' it out. You can tell when you've hooked it because you can pull the needle by pulling the strap. Once it's hooked, you have to carefully pull the needle out, keeping the strap from sliding off by angling the needle away from the other hole. Good luck. Took me quite a few tries.
