I haven't used for a year. it has been sitting downstairs and hasn't been disturbed at all.
Sounds like the power supply has failed. That's where you plug the power wire into it. You could try opening the case and re-seating the main plug connector on the mother board. This is the big bunch of wires that ends in a 24 pin plug attached to the main board.
(See if you can borrow a power supply from a handy family member?) http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
SOURCE: HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
SOURCE: compaq presario sr1303wm not powering up
Try another power cord first to be sure; if that doesn't works, then replace the power supply.
SOURCE: Green blinking light on back but will not turn
Its possible that the power supply inside the CPU is unable to provide the required DC Voltage as required by any PC. Try and exchange it a friend's SMPS of the same ratting(wattage) as yours and see if the PC works. If not, remove the RAM from their DIMM slots and clean the contact points. But if the RAM gets spoiled/damaged the MOBO should respond with continuous beeping sounds......sodeep
SOURCE: green light comes on and the fan but monitor will not
Does it display on your monitor "No Input Signal"? If so it could very well be your motherboard. Same thing happened to me. :(
SOURCE: Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
