When I push the "open" button I can hear a sound but the tray doesn´t come out. Is there anything I can do? Many thanks in advance!
SOURCE: BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
SOURCE: yamaha dvr-c300 dvd playeer
on my sreen it say speaker error ,and no sound is coming out on my yamaha dvr-c300
SOURCE: yamaha s2500 dvd player
Hello, frustrated Yamaha owners.
I have destroyed two of these machines to remove my precious CD's. I did discover this today:
1. There is a fuse but it is soldered onto its circuit board.
2. There is no easy way, like using a paperclip on the old computer cd-rom drives, to release the cd/dvd tray. However, when I destroyed my second player, I noted there is a rather large piece of metallic tape on the bottom of the player to the right side of the front of the drive on the metal bottom cover plate of the machine. It is covering a slot about an inch long. If you carefully remove the tape and use, say a phillips head screwdriver, starting at the right side of the slot as you face the front of the player, you can slide a plastic bar that will free-up the tray slightly allowing one to pull the tray out and save the cd or dvd. I would do this with the player upright but hanging over the edge of a table so that the freed cd doesn't bang around against something in the process.
For what it is worth, I hope this helps.
Yamaha should be ashamed of producing a product at this price point with an issue like this. At the very least there should be a fail-safe way of removing a cd/dvd from the drive regardless of the issue with the electronics or drive mechanism.
