Question about Bell & Howell Video Cameras
DNV900HD camcorder stuck in test function!
The camera was working fine, and I went to turn it on today and it is stuck on test function. I've replaced the batteries, plugged it in to my computer, and read the manual. Nothing has worked. please help!!!
5 Related Answers
Anonymous
SOURCE: PLEASE HELP ME! Panasonic firewire connection won't work!
u need to call panasonic 4 the softwarw...there is a software the sell 4 the firewire issue....
Posted on Dec 15, 2007
Media Man
SOURCE: the camera function will not work
Hey Uttado,
Check to see if the stanby lever that surrounds the record switch on the back of the camera has inadvertently been put on standby. If this has happened, the VCR will work but not the camera. Move it off of lock to standby and it should crank right up.
Posted on Jun 16, 2008
Anonymous
  • 4 Answers
SOURCE: condensation operation
I found instructions with pictures on fixing this problem online at
http://www.freewebs.com/ltooz/03jvcgrd70u.htm
The process involves taking the camera apart.
Other forums I have looked at have mentioned waiting the error out or allowing the camera to air out.
Posted on Jan 31, 2009
Anonymous
SOURCE: Charging the battery on Jazz HDV178 digital camcorder
Go to Ebay and type in NP60 you will see batteries and charger order the charger and charge your battery it solved my problem. I also bought 2 batteries waay cheaper than the local stores!!!
Posted on Mar 09, 2009
Anonymous
SOURCE: Nothng is working.
Nevermind I used a different SD card and it worked
Posted on May 24, 2009
My Flip Mino HD camera turns off while recording!
I had the same problem! But I turned it off, stuck a paper clip in the little hole inside the hole at the bottom for 10 seconds, then i held the power button for 5 seconds till it turned on and it works just fine now :)
2answers
Bell and howell dnv900hd won't power on with battery packs
The battery pack might be "dead". Get a new one.
Kodak playfull will not turn on
probably the camcorder wasn't meant to be underwater or a underwater camcorder can only function properly during a certain depth you go in the water.. but if you go over the limit of the depth you went underwater it would shut down and not come back to function properly.
When I connect My Samsung VP-D77i Camcorder to my Laptop I always get a message saying "cant open camera device". My Laptop does not have a fire wire port but only with USB ports. It has Windows 7 Pre
First, try attaching the camcorder via usb cable with the camera OFF, then turning it on. This may trigger Windows to activate the driver scanner and activate the driver. If you've been attaching with camcorder off, try attaching with it on, to see if that activates driver installation.
If that doesn't work, you may have a low-power usb plug; often the usb ports in the back of the computer put out more juice than the handy ones on the front. You may also need a shorter and more robust usb cable; I've found with various cameras and phones that certain usb cables work fine for recharging but won't necessarily provide adequate data transfer.
Aiptek GSV 1080P HD Camcorder external mic feature won't work.
Possibly an impedance mis-match - check in both manuals.
1helpful
2answers
I've bought a new samsung pl121 camera & taken a
Your camera is obviously defective. It may have been a return and resold to you. In any case, you should return it immediately....this problem will only get worse.
Hi, 1and half years ago I bought a HDR-HC9E. I didn't use it alot, but now I have started to use it. I've made 5 cassets in 5 days and everyday I have copied in my macbook pro without...
I'm sorry for the difficulties you're experiencing as the i.LINK connection from the Camcorder is not recognized by two different Computers. Since the issue persists with two computers, it seems that the issue is with the Camcorder itself.
I suggest that you try resetting the Camcorder and check if that helps. To reset the Camcorder, please press the reset button behind the LCD screen using a sharp pointed object. Also make sure that the Camcorder is turned ON when pressing the reset button. You can locate the RESET button from the below picture.
If the issue persists after resetting, service may be required. However, please click hear to view the troubleshooting steps recommended by Sony. I have reviewed it and found that you have already performed all these steps. However, please check whether you missed something.
Thanks for understanding. Please let me know if you require any clarifications.
3answers
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Eject button for cassette not working
look for a small pinhole to insert a pin to reset while powered up
Video Cameras Logo
Top Bell & Howell Video Cameras Experts
ray gallant
Tom Chichester
Tony Parsons
Tony Parsons
Are you a Bell & Howell Video Camera Expert? Answer questions, earn points and help others
