Question about Optimus Heating & Cooling
Why does my dish heater kee turning itself off?
Sometimes the caution light comes on. I can usually turn it back on after a f ew minutes. It IS NOT set to thermos so its not turning off because it has reached a certain temp. Once it is able to come back on, it will not turn itself back on. I have to manually turn it on.
Posted by Karen Owens on
denis watterson
Incress water presher to
Posted on Jan 19, 2012
Electric range for maytag gemini stove doesn't coem on. Clock and controls appear to function. This is after I turned the house's breaker off then on again. The "On indicator" light does not come on when I...
Turn it off at the circuit breaker and leave it off for a few minutes,sometimes the microprocessor will reset itself. When you turn it back on make sure the safety switch is working ok they usually have a test button on them.
May 01, 2014 | Maytag MER6772 Gemini Electric Kitchen...
E02 comes up on display on my Siemans dishwasher
The model number is usually plated on the left inside panel of the door, however, that is not always true and could be at the back which is hard to get to unless you take the dishwasher out.
The E02 error with Siemens dishwashers would mean the washing is happening without the heater turning on. This means the dishes may not be coming clean, the wash cycle is long and dishes do not dry.
It is linked to heater relay in control unit being faulty and could be also related to the heater itself being faulty. Worst case both are to be replaced.
A very costly affair. Would help if you can find the model number.
Dec 29, 2012 | Dishwashers
Fault E02 on Seimans dishwasher
I think you already raised this problem and I have answered.
We have a new OFC2400TIF heater. We have set a program which worked for a day. Now the heater will not work on either manual or auto. The display lights are all on, the screen indicates that the heater is...
The heater may need to reset itself. Turn the Master ON/OFF Switch to OFF and unplug the heater from the wall outlet. Wait 12 - 15 minutes and plug the heater back in. Turn the Master ON/OFF Switch to ON and set the controls as you normally would. Hopefully, that 12 - 15 minute timeout allowed the heater to reset itself. If this continues to occur, contact Dimplex Technical Service at
888-346-7539.
Hope this helps you to further troubleshoot and solve the problem.
Apr 24, 2011 | Dimplex OFC2000 Oil Filled Radiator Heater
After the major 90k service the engine light is on.
Sometimes mechanics fail to reset the sensor. Try disconnecting the POS battery cable for about 15 minutes. Use caution to ensure it does not contact any other metal surfaces. I usually wrap it in a dish towel.
Apr 02, 2010 | 2002 Jeep Liberty
Red caution light
The red light is in conjunction with a safety. This is there in case something goes wrong, the heater doesn't overheat and possibly catch fire. If its not getting too hot, and its sounds like its not. The safety needs to be replaced. It will be a little disc shaped thing with 2 wires connected to it. If this heater also has a tip over safety, there also may be some type of mercury switch too. If you are so inclined, when you find the safety disc it should have some numbers on it. This indicates the temperature it is made to turn off at. After removing it, connect the 2 wires together and turn the unit on with a thermometer in the spot where the disc was. If the temp. doesn't go higher than the #'s on the disc after 45 seconds like you said, then you know positively that is the problem. If it gets hotter very fast, then the elements need to be looked at for defects. If there are no numbers on the disc or you cant find a replacement, then it may just be easier to buy a new heater.
Mar 03, 2008 | Patton MH761 Utility Heater
The Caution Light ?
MILKHOUSE HEATER "CAUTION LIGHT" SOLUTION: Before I explain, let me clear this myth up: this is NOT an issue with the pendulum safety switch (some mistake that for a "mercury" switch). To begin, unplug the heater. Open it up and clean it out. I mean, buy a can of non-chlorinated brake cleaner and squirt all of the contacts good. Below the fan there is a sensor mounted on the heater element box on the bottom. That goes bad and causes it to trip. While you are there, squirt the motor bushings good with the brake cleaner and dab a drop of synthetic motor oil (just a drop) on EACH of the two motor bushings. Personally, I rewired this and bypassed all of the safety features. You can bypass that sensor without soldering or cutting any wires. All you have to do is unscrew the wires from the holder and then unscrew the tiny nuts and tiny bolts. Then bolt the together at one end (note the position) and put it back in the holder and tighten the screw to hold it in. This method fixes the issue completely as it removes the sensor from the equation. In fact, I just did that on my third milkhouse heater and it has been running solid for the last 15 minutes. Use your modified heater with caution! Let the brake cleaner dry before you energize this device!
Nov 30, 2007 | Patton PUH9000-U Heater
Set turns itself on for no reason (and sometimes off)
on menu, pick customize, then set the video input sensor to off.
Dec 31, 2006 | Hitachi 43UWX10B 43" Rear Projection...
Heating & Cooling Logo
294 people viewed this question
Top Optimus Heating & Cooling Experts
gbob59
Marvin
Marvin
Vernon Taylor
Are you an Optimus Heating and Cooling Expert? Answer questions, earn points and help others
