Question about Amana Freezers
My amana upright freezer was working fine, but transported it to another location when I plugged it back in, it started to make a buzzing noise. How do I turn this off or fix it?
Posted by jumasanu on
FRED GRANT
    Scholar:
  • 84 Answers
Hello....First...when you transported the freezer...you must sure the unit stays in the vertical position and not laying on it's side...back..or front....If the freezer is making buzzing noises...adjust the thermostat setting down until the buzzing stops...and increase the setting gradually until the desired temp is reached...it could take 24 hours for it to stablize...I hope this was helpful.....PEACE.......
Posted on Jan 25, 2012
5 Related Answers
robert samples
  • 1314 Answers
SOURCE: amana self defrosting upright freezer - drain plug
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
Posted on Jan 18, 2008
Anonymous
  • 184 Answers
SOURCE: Loud buzzing noise
IF YOUR FREEZER HAS A TEMP ALARM, USUALLY LOCATED IN FRONT,BOTTOM, RIGHT CORNER, THE TEMP IS PROBABLY ABOVE THE SAFE TEMP FOR FREEZERS, (10 DEGREES) AND SO THE ALARM WILL SOUND.
THERE SHOULD BE A SWITCH IN FRONT TO SHUT OFF THE ALARM UNTIL THE TEMP GETS BACK DOWN TO ZERO. THEN YOU CAN TURN THE ALARM BACK ON.
IF YOU PLUG IN THE FREEZER AND TURN IT ON, IT SHOULD BE BACK DOWN TO NORMAL TEMP (IF IT IS EMPTY) IN ABOUT 24 HOURS. IF IT ISN'T, YOU HAVE OTHER PROBLEMS. CHECK TO BE SURE THE COMPRESSOR IS RUNNING.
Posted on Apr 05, 2008
Anonymous
  • 19 Answers
SOURCE: Freezer quit working
I suspect when you lifted or moved the freezer, you tilted the compressor such that the oil washed out into the refrigeration lines. Common when people tilt refrigeration equipment the wrong way.
Posted on Feb 07, 2009
Anonymous
  • 585 Answers
SOURCE: Hot exerior walls in a brand new Kenmore 28042 upright freezer
There should not be a fire hazard but you should be concerned that the freezer could break down if it is not allowed to vent the heat it produces. The freezer is not intended nor designed to be enclosed The manual must indicate specifications for minimum clearances for rear, top and sides, and may even be indicated on the big yellow sticker on the inside of the door. The clearances must be respected or again, the unit will fail, and the warranty may be voided in such cases.
Posted on Jun 28, 2009
Anonymous
SOURCE: whirlpool upright freezer making buzzing noise and not working
I had a similar problem yesterday. I woke up and the freezer was not working anymore. It would make a buzzing noise and then it would click and shut off. I looked online for some possible solutions. Here is what I did:
I unplugged the fridge. I pulled it out and took off the cardboard backing. I used an air compressor to blow out all of the dust and dirt that had accumulated on the condenser coils. A shop-vac just wasn't powerful enough to pull out all of the dust/dirt. After that, I plugged it back in....and the same thing was happening. It would buzz, and then it would click off. I figured out that the "click" was coming from a starter relay (a small plastic piece attached to the big black compressor). I detached the plug from the relay and then detached the relay from the compressor. The relay was burned out. It turns out this is a common problem with the relay. I replaced the relay for $50 (from an appliance parts store) and put the whole thing back together in about 10 minutes.
I plugged the fridge back in and the compressor started, and now the freezer works better than other. I saved about $400 doing it myself, all in about one hour. And better yet, my wife was very impressed. Not bad for a doctor.
Posted on Jul 04, 2009
When i moved my kic chest freezer model kc0021-Aa, I heard an light explosive sound and now the freezer does not go on.
The following is the GE moving instructions. If you have started before the 24 hour rest period and the unit had been rotated from vertical have the compressor inspected.
FREEZER MOVING INSTRUCTIONS Please use the following steps when relocating an upright or chest freezer:
  1. Disconnect the power cord from the wall receptacle.
  2. Remove the food, defrost, and clean the freezer.
  3. Use blankets to protect the freezer finish from scratches.
  4. Place the freezer on its side for moving only if you have no other choice.
  5. When transporting a freezer, keep it in an upright position. If transporting it in an upright position is not possible, lay it down on the compressor side of the unit. Be careful to secure the door to prevent it from opening.
  6. If it has been transported on its side, set it right side up in its final location and allow the freezer to sit for the same amount of time that it was on its side (24 hrs max.). Do not plug the unit into the electrical receptacle without allowing this settling time. The unit can be damaged if it is plugged in prematurely.
If the unit was transported in an upright position there is no waiting time required.
Hope this helps?
Apr 07, 2017 | Freezers
I had to lay down my upright freezer for transport how long before plugging in and using it
Here is a tip that I wrote on moving refrigerators...if you did not do it thisway then you may well have ruined a perfectly good refrigerator.
Moving a Refrigerator What is thebest way
If you already have moved it wrong, you can sometimes get it working byplugging it in and unplugging it a number of times with an hour or so inbetween.
heatman101
Aug 07, 2011 | Amana 19.7 cu. ft. / 558 liter Upright...
Making alarming buzzing sound. Still freezing fine
putting unfrozen food in a freezer can raise the temp to cause it to go off allow 24 hours for it to stop if it dont replace the buzzer
May 23, 2010 | Whirlpool Upright Freezer EV161NZRQ
Buzzing in a full freezer with icemaker model no. 253.44133802
try cleaning vents/drain holes in whole unit this should allow more air to flow.also when did you last manually defrost whole unit.....
Feb 03, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
Whirlpool upright freezer making buzzing noise and not working
Jun 29, 2009 | Whirlpool 20 cu. ft. / 566 liter Upright...
Jan 30, 2009 | Freezers
Amana 25. cu ft..freezer not working...making rattling noise now and then
Check the defrost timer, rotate it until a solid click is heard. If your unit starts to work replace that timer. Good Luck
Aug 05, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Loud buzzing noise
Apr 01, 2008 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezers Logo
371 people viewed this question
Top Amana Freezers Experts
Muntejaya Ginting
Muntejaya Ginting
Dennis Boxerman
Are you an Amana Freezer Expert? Answer questions, earn points and help others
