Question about Drills
I need a switch for a red head 606 hammer/drill
5 Related Answers
emissionwiz
Marvin
  • 85239 Answers
SOURCE: Dewalt cordless drill
You have burned out the drill motor, it is shorted, the battery smoked due to a direct short, one thing I don't understand why the thermal limiter didn't trip in battery pack, I would contact manufacturer and try to get hem to buy you a new drill.
Posted on Aug 29, 2008
Roscoe007
  • 101 Answers
SOURCE: Broken Forward/Reverse Switch on Bosch Model 1198VSR Hammer Drill
Yes .. should find it here http://www.toolpartsdirect.com/bosch-tool-parts.html
Hope this is Helpful ! Thanks
Posted on Dec 16, 2008
rowdy45176
David Ford
  • 2176 Answers
SOURCE: Hammer switch jammed on Makita HP1621K/2 Percussion Drill 2
I looked at Makitausa.com website and it appears that you might be correct. there are 4 parts to this assembly and one of the problems might be the cam holder position #17. I would suggest that you go to their site and take a look at how the parts are supposed to be. I used the model number in the large header so this might not be the exact one that you have. Let me know and I will try and help further.
Posted on Feb 06, 2009
Anonymous
SOURCE: Hammer drill won't run
you have to activate the batteries by putting them in to the charger for a minute first, they are in an inactive state when first bought
Posted on Mar 30, 2009
Anonymous
  • 142 Answers
SOURCE: dewalt dw567
if i'm confused i'm sorry, but don't confuse and impact driver with a hammer drill
2 different tools altogether
Posted on Feb 27, 2010
Red spanner indication light is on is this normal
this usually means that the drill needs a professional service
Jan 28, 2015 | Hammer Drills
Keeps switching from hammer to drill
There is a spring loaded detent that keep the switch from moving. It is either dirty or needs replacing. The whole front of the unit needs to be opened to access it.
Is this your unit?
Parts:
Website: www.ozito.com.au
Email: [email protected]
I hope this helps. Please give feedback.
J
Dec 09, 2013 | Drills
Dewalt dw511 hammer drill won't hammer, only
The hammer inside the drill head are most likely damaged ans/or broken, it is likely the best thing to do is just replace the tool.
Feb 15, 2012 | Dewalt Drills
How do you work the keyless chuck on the 6.5 amp 3/8" rear handle pro drill?
Most drills with the keyless chuck work this way. Put the drill into reverse. Grasp the chuck with your left hand, and then pull the switch slowly. This should release the chuck. If your drill has no reverse, then grasp the chuck again with your left hand and hold the drill with your right hand. Turn the chuck with your left hand quickly, this should release the drill as well.
Mar 17, 2011 | Craftsman Garden
I need the electric schematics, trying to replace the switch.purchased switch thru the dewalt website.
Schematic from a dealer for converting an old type 1 switch on DW-505 hammer drill a to the new switch. 124845e.jpg
Oct 04, 2010 | Dewalt DW505 Electric hammer drills
My 24v cordless drill is working ok but the switch on the side of drill for turning hammer on and off is missing. what spare parts do i need to get. would it just be the switch hopefully nothing else fell...
In order to switch from hammer to non hammer on the 13624 there is a ring on the clutch near the chuck. The button on the side is for switching from forward to reverse. The part number you will need is 2601099112. This is something that happens quite often on these drills and you may consider getting two. They are less that 5 dollars each.
Jun 18, 2009 | Bosch 13624 24V Cordless Hammer Drills
Drill will rotate but will not hammer under load
most of these types of tools have a manual switch it will be located on the body of the drill just behind the chuck on top or bottom or oposit the grip handle. some models have 2 switches.you want to make sure the switch points to the picture that shows a hammer and drill together.also rember it needs to have down pressure for the hammer part to activate.
May 19, 2009 | Dewalt 1 9/16" Rotary Hammer Drill D25551k
Damaged chuck
Grasp chuck, reverse it until fully open. Look inside where bit goes and should be an allen head or torque head screw holding chuck to motor arbor/shaft.
May 14, 2009 | Makita 5/8" 2 Spd Hammer Drill
Feb 06, 2009 | Makita Drills
Drills Logo
159 people viewed this question
Top Drills Experts
Marvin
Marvin
Tom Chichester
Bill Boyd
Are you a Drill Expert? Answer questions, earn points and help others
