How to hook up a IPOD to the aux
SOURCE: i have the panasonic cq-c8303u radio and i would
You need to get the Direct Cable for iPod® (CA-DC300U) from panasonic. This allows you to plug in and control your ipod from your headunit. There is also the expansion module (CY-EM100U), however I am not sure if this is necessary if you have the Direct Cable. The Direct Cable might plug directly into the back of the headunit without the need for the expansion module. Check with the company before purchasing one or both. If the direct cable requires the expansion module, then get both, however, I think the direct cable works independent from the expansion module. Again, contact the company about this. The expansion module also lets you plug your ipod as well as other devices into your headunit, however I don't think it allows you to control them via the unit. I think if you want to control the ipod from your headunit, you just need the Direct Cable for Ipod®.
SOURCE: Panasonic CQ C1100U amp output?
Yes, the Panasonic CQ-C1100U can be connected to a 2-channel amp. It has a single set of preamp outputs. I'm attaching an image of the connection shown in the Panasonic user manual. The appropriate connection is the one without the dashed line. The dashed line showing a 2nd set of outputs only applies to the 1110, 1120, and 1200 models.
Hope this helps. If it does, please rate as "FixYa". Thanks!
SOURCE: Connecting iPod to Panasonic CQ-C5310U
I'm pretty sure that there are RCA jacks in the back of the unit for the aux input. Don't have my owners manual so can't really say, but if there is an aux input, there is sure to be some RCA jacks in the back. So if you take the stereo out, look for those jacks then attach a 1/8 "Y" connector. Then route that wire to the front. Then you'll have something to connect your mp3 player to. =)
SOURCE: using an ipod with CQ-DFX403U
http://www2.panasonic.com/consumer-electronics/support/CD/model.CQ-DFX403U
This is the link to your units pdf manual. It also covers a 7 series model which does have "Aux in" Your unit does not. You do have the capability to add a cd changer via the link on the back of the deck but it is Not an auxillary input. Now, it is correct that you could use a FM modulator running thru the tuner on 87.1 or 89.1. I think the confusion on this unit was a quick glance at the manual. It does have an "audio in" but it is specific to the panasonic disc changer and triggered thru the changer din cord. which is why you see no "Aux" on the display nor hear any audio. If you look at page 5 in the pdf version of the manual it states that the 403 does "Not" have aux in. The manual reads tricky on the other pages, sounding and looking like they are detailing the 403 when in fact the example is the 783. At the moment I can't think of a "good fix" for this pickle. I'll noodle it thru and if I can get you a solid way to make this do what you wish without lots of signal loss I'll post another comment. Hope this helps explain what's happened.
