I just moved into a home and while installing my electronics, I hooked up my Kodak easy share 500. it powers on, then powers off in 20 seconds. I have confirmed the power is good...the lights come on for 20seconds, but not sure the problem. I have installed a new ink cart so that's good and paper is in the feeder
SOURCE: new ink cartridge for Kodak Easy Share 5300 will not work
The version of firmware you originally had on the printer when you
changed the ink cartridge was bad. There is a known issue that when you
put in a new ink cartridge when the printer is in the error state
"COLOR INK
EMPTY. REPLACE COLOR INK CARTRIDGE" the unit writes that value to the
new ink cartridge so you will continue to have that error.
So to fix
your problem Open the access door and Remove the ink cartridges. Then download and install
the new Firmware. Heres the link.
Kodak AiO 5300 Firmware
Then sadly you have to go get another new ink tank
and install it.
If you can get through to kodak you should request reimbursement of some sort like a free set of ink tanks.
I hope this helps
SOURCE: KODAK EASYSHARE 5100 SERIES
a blinking yel light w/ "F" on display means MEDIA SENSOR FAILURE
"P" PRINTHEAD FAILURE
"S" SCANNER FAILURE
SOURCE: Kodak 5100 only prints half the page
My Kodak Easy Share 500 decided to only print 1/2 the photo today. For over 1 year it has worked just fine. Any ideas?
SOURCE: my kodak printer easyshare 5100 not responding
maybe..the scanning is most likely from something else..try new drivers first
http://tinyurl.com/6qcpgy
SOURCE: Printer Kodak Easyshare 5300 Will not print black ink
Here are the things you will be asked to try if you call support. They may fix the problems as well. Taking the printhead out and putting it back in is the big helper.
Remove the black and color ink cartridges.
Right above where the black ink cartridge was, in the top left hand corner of the printhead, push up towards the ceiling and you should be able to push a button that releases the printhead.
Place the printhead right back into the printer and push straight back on the back wall.
You should hear a loud snap.
Replace the ink cartridges which should snap as well.
Close the printer.
After about a minute or so the printer will ask you to do a calibration.
Insert a paper and press start.
Scan the calibration sheet.
After that, in the menu, do a printhead clean.
(If this is a 5100, do it in the home center ->? in the top right ->Maintainence ->Clean Printhead.)
Do one basic and one deep.
Print a demo sheet to see if anything has changed.
If the picture looks better, continue to do cleans.
In the event that it does not, the printhead will need to be replaced and since the printer is still under warranty, Kodak specialists will try to overnight you a printhead.
The whole process is short and free.
The number for Kodak AiO Support is 1 800 421 6699.
