Whirlpool GHW9400 Front Load Washer Logo
Anonymous Posted on Jan 11, 2018
Whirlpool GHW9400 soap&bleach dispenser full of water after wash completion
After a complete cycle the soap and bleach dispenser is full of water. The machine washes great. If you were to pour the soap and bleach in on top of the water it would start the siphon and it would all run out. No service department has been able to fix it. This started after it was about 3 months old.
5 Related Answers
Anonymous
  • 5911 Answers
  • Posted on Feb 11, 2008
SOURCE: Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
jm-montgomer
  • 9 Answers
  • Posted on Jan 31, 2009
SOURCE: Whirlpool Duet GHW9100L pours water out of the soap dispenser dra
probable cause is there is an article of clothing that is stuck between the outer and inner tubs, in the area where the dispenser water and detergent enter the machine. you can run your hand around the rubber boot and you might be able to remove the article, it will be in the upper left part of the machine. if nothing can be found than you have a plugged up dispenser hose.
Anonymous
  • Posted on Jul 25, 2010
SOURCE: LG Tromm Not Dispensing Bleach
i will figure it out mine is doing the same - sherman@all-waste,com
Anonymous
  • 15935 Answers
  • Posted on Sep 27, 2010
SOURCE: Whirlpool duet washer leaking/pouring water out of
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^^^^
richroth
Richard Roth
  • 9472 Answers
  • Posted on Jan 21, 2011
SOURCE: The fabric softener (downy) won't dispense. It
You will also need to clean the the dispenser hose that goes into the machine.
1helpful
Finished Clean Washer cycle and my bleach dispenser full
It's normal for all washers with a sanitize or tub clean cycle to leave diluted bleach in the dispenser
4answers
My clothes have a musty smell after being washed
run a wash load (no clothes) with 2 cups of Clorox brand bleach and use hot water, that should help.
Very damp smell
Make sure there are no leaks from the machine. look behind it and check the water inlet hose and connectors for any damage. Also look under the machine for any water as this may indicate a leak from the internal hose and pipe work and / or water pump. Also check that the outlet hose is completely clear of debris and soap scum build up and check that the filter is clean.
To keep the machine clean of waste build up and to keep any bad odours away
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
1helpful
The pump on the Bosch WFB 2000 front loading washing machine doesnt seem to be pumping all the water out, it leaves about 40mm of water in the drum. It though pumps and seems to be working, as it does pump...
  1. Check the filter is clean.
  2. Check that the outlet pipe is completely clear of debris and soap / detergent scum.
If this does not cure the problem then it may be there is soimething trapped in the water pump or thst the pump is actually defective which will mean a new pump is required.
To keep the machine clean of waste build up and to keep any bad odors away
4helpful
2answers
Bleach and Fabric Dispenser not working
Got a Brand new LG ~ WT5001CW toploader today. I did 2 loads of wash. Theres a Bleach Dispenser on the top left side but I didn't use it. In the middle of my 2nd wash I noticed the bleach dispenser was full of water. I thought well maybe after the rinse and the spin it would take the water out. Well when the cycle was complete the Bleach Dispenser was still full of water.
I took the Bleach dispenser out and checked the holes to see if anything was plugged, didn't look like it. Was wondering if anyone knew how to solve this problem or do you think that since I took the bleach dispenser out and put it back it that it might work for my next load ??
Any opinions will be greatly appreciated !! Thanks Much !!
Fabric softener and bleach dispensers
Call the tech. one came out this week and said the system solenoid is always engaged causing the bleach and detergent to dispense when drawer is pushed in
2answers
Water stays in Gasket on Whirlpool GHW9400 Front Loader
The tiny holes at the bottom of the door seal are blockedcarefull push a small screwdriver through yhem to clear them out
2helpful
2answers
Removal of washing machine soap dispenser - Indesit
hi sue,
i've check the web and i found thatt you just have to pull the soap dispenser towards you. if some clips are rising when you pull it, gently press it down and continue pulling it.
tnx 4 using fixya,
drcool
2answers
Washer smell
the easy way it completely wash out a washer is by taking your soap dispenser out washing it and pouring bleach into the machine through the dispenser put on a full programme after it has finished you will have to put the washer on a full programme again with nothing in it and no more bleach this will flush the system out of the bleach so it should not stain your clothing but 1 other item you will need to check and that is your door seal if you close your door after each wash then what happens is it stays wet which gets moist on it a this starts to get mouldy and then starts to smell you will need to change your door seal, never close your washers door totally this will prevent this from happening again
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
