I need a needle for a Euro Pro Model 416 sewing machine. I have only one and it is bent. I have straightened it out but am afraid it will not last too long. [email protected]
SOURCE: friends broke needle on my euro pro multi stitch sewing machine.
According to Euro-Pro.com
Where can I buy new needles?Answer: The needles are universal and can be purchased at any sewingmachine notion department. The size and type of needles should beappropriate to the fabric used. See the needles and fabrics chart inyour instruction book.
http://www.euro-pro.com/europro/faqdetail.aspx?modelno=9000
has all the information including a downloadable manual (pdf file)
SOURCE: Can't figure out how to thread the needle
Here is the manual.
http://www.euro-pro.com/europro/manuals/8260.pdf
Good Luck and please Rate FixYa!
SOURCE: Needle breaks on my Shark Euro-pro model 361 my
Are you inserting the needle fully into clamp? You may have a bad lot of needles that werent straight. Try sewing by hand with machine to see exactly where and when needle breaks, then you might be able to solve problem.
SOURCE: I have a Euro-Pro 473 model sewing machine, I?m
If you're having the same problem we did, the attachment is installed too high on the bar. Move it down as far as possible and see if that solves the problem. If it doesn't, check to see whether the machine is belt-driven; did the belt break or slip off?
