Question about Samson Technology Zoom Q3 Handy Video Recorder
User Manual for Zoom Q3 Handy video recorder - Samson Technology Zoom Q3 Handy Video Recorder
Posted by Roberto Fenton on
1helpful
Virus in Camera
Your model doesn't come with built-in storage, so that makes this easier. You should first put in another SD card and see if that helps. If it does, you'll probably have to reformat your first SD card, wiping everything on it. Sometimes formatting issues appear to Windows like a virus on an external device. If this does not fix the virus warning problem, then your virus is likely on your computer, not the camera.
A good virus scanner/remover might be in order for your computer.
Hope this helps. Good luck
2helpful
How to eliminate virus in my zoom q3hd
Have the memory card SD/HC checked by any antivirus software.
Format and clear if necessary.
Rest assured. There CANNOT be any virus in your Zoom Q3HD.
H1 won't connect via USB
This page has a download for a driver........ https://www.zoom-na.com/products/field-video-recording/field-recording/zoom-h1-handy-recorder
Also try a different cable....... Good Luck!
Zoom Q3 ERROR 35390
I have the same problem.. Doe you have a solution yet?
Greeting from holland
Power button broke on zoom q3
There is a design defect in the zoom Q3 video/sound recorder. The power button is tiny and only held by three finite solder points that cannot take the regular force of one pressing on it. The solution is simple and permanent. Since the Samson tech Zoom Q3 comes part easy you have access to the part. The power switch falls of and stays inside. Get a fine tip soldering iron and resolver it, but the real trick is to put some liquid plastic support in behind the power switch and around it so that it will no longer be affected by the force of pressing it on and off. Video here: http://youtu.be/SwHJ9b6yNrc
3helpful
Need english translation of zoom H4n handy recorder
You can download the English manual from:
http://www.zoom.co.jp/english/download/manual/english.php
Direct download link: http://www.zoom.co.jp/archive/English_Manual/E_H4.pdf
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks
Can't connect the h4 handy recorder to a mac
If you are using a Mac running Leopard (Sys 10.5), you need to upgrade the H4  firmware from Zoom website
http://www.zoom.co.jp/english/download/software/h4.php
You will need an external SD card reader.
Good Luck
1helpful
Sony handy cam CCD-TRV46E PAL
Please use Video Head Cleaning cassette to clean its video head. I'm sure, you get error sign of Dirty Video Head in view finder while recording.
Samson Technology Zoom Q3 Handy Video Recorder Logo
Top Samson Technology Cameras Experts
Ekse
ADMIN Canada
ADMIN Canada
Are you a Samson Technology Camera Expert? Answer questions, earn points and help others
