Question about Samsung RS2630SH Side by Side Refrigerator
Samsung rc21dcns side by side fridge freezer: The condenser fan motor won't run. I checked the fan motor and the board on another identical samsung rc21dcns and the board and the condenser fan mo
Posted by ymfox on
5 Related Answers
Anonymous
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
Anonymous
SOURCE: Samsung side by side fridge/freezer
I bought one of these Samsung fridges a couple of years ago and just as the warranty run out, It started making a noise then the fridge compartment stopped cooling, so I did a web search and found out this is a common fault.I searched the web and found a step by step guide on how to fix on EBAY, under Samsung fridge Fault and it cost me £10.00 Only took me half an hour to fix it and it has worked fine ever since.A1+++ FIX
Posted on Oct 24, 2007
bobotfel
Felizardo Erilla
  • 241 Answers
SOURCE: samsung fridge RS2630SH, side by side, icing up on freezer.
You have to pull out the sensor from the board and test with tester, both sensor should read the resistance of 10,000 to 20,000 ohms. The reading that you show is very low it means that the thermistor is out of range and need replacement.
Posted on Mar 08, 2008
DrLindquist
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
Anonymous
SOURCE: noise from back of Samsung freezer near ice maker model RS2530BBP
I figured out what was going on with mine and fixed it (without needing to buy replacement parts). In the freezer section, about a third of the way down the back of the freezer was a bulged-out plastic covering, held in place by four screws. The two screws on top are covered by oval plastic that pops off easily with the help of a knife. If you take the screws out, the hard part is that the bulge/cover is still going to be frozen in place. I used an old-fashioned bottle opener/churchkey to gently pry the compartment open. When I got inside, it was easy to see what was happening--the plastic fan was hitting ice that had built up behind this cover. I chipped away all the ice, and presto--no more noise!
Posted on Dec 11, 2008
Whirlpool freezer won't freeze
you need to send the model number so i can see what fridge you have,is it a side by side freezer on top or bottom.check the back inside wall of the freezer to see if any ice or like snow is on the back inside wall of the freezer,if so you have a defrost problem,if it's a top freezer is there any water leaking into the fridge section,check under the crisper draws,if water is there you could have a blocked drain in the freezer,the water that's from the defrost mode leaks into the air ducts and freezes,or you could have a freon leak in the sealed system,remove the inside back wall of the freezer and check the frost pattern on the evap coil,if there's frost just on the top of the coil and nowhere else on the coil you have a freon leak,one more thing you could have a bad evap fan motor,open the freezer door,you should hear the fan blowing around,open the freezer door and push and hold the door or light switch in for a minute and then let it out,if the fan doesn't run it could be bad.the last thing is the compressor isn't running and you're hearing the condenser fan running and not the compressor,the start device on the compressor could be bad,feel the compressor,is it hot and feel it to make sure it's running.so bad start device,freon leak,defrost problem or bad evap fan motor or condenser motor.if you get back to me and let me know what you find and send the model number i can help you better.
Nov 02, 2011 | Refrigerators
My fridge gets really hot on top and between the fridge and freezer where the door meets
next time send the model number and brand name.usually when this happens is the condenser fan motor isn't working.pull the fridge out,remove the bottom back panel and check the fan to see if it's working,if it is check the condenser coil to see if it's filled with lint and dust,it could just need to be cleaned out but if it's that hot most likely the fan isn't running,if you get this tonight check it now,if the fan isn't running you could blow the compressor,the condenser fan blows and keeps the compressor cool enough so it doesn't overheat by moving the hot air and the heat also esscapes through the condenser coil so if that's clogged with dust the machine will run hotter than normal,if the fan isn't running you can stick any window fan back there and blow it onto the compressor to keep it cool until you fix the condenser fan motor,this way you won't loose any food and if the compressor goes it's new fridge time,to much to repair.hope this helps and good luck with your machine.one more thing,i've found the fans not running and by pushing the blade it runs again,if this happens the fan could run and never have a problem or it could stop an hour later but i would change it out no matter what.if it's a G.E. fridge and the motor isn't running,most likely it will be the computer board,i've found 10 machines doing this and the temp. settings turning on and off or the evap fan motor in the freezer runs slow and then fast and the condenser fan isn't running or running slowly,this is why you have to send the brand name and model number.
Oct 28, 2011 | Refrigerators
Sub zero 532. freezer works fine --0 degrees. fridge wont get below 50 degrees. cleaned condenser fins- still no decrease in temp
check the fan that runs between the freezer and the fridge --check fan for ice blockage -debris-or damage / clean or clear blockage --if not running test wiring and connections as well as motor /repair or replace //also check fan damper is not frozen or blocked its flap that opens and closes for air to flow //----ur fridge side is cooled from the the freezer side the cold air is blown in from the freezer if fan or damper is not working correctly than fridge is usually warm and freezer is working properly
Jun 28, 2010 | Sub-Zero 690 Side by Side Refrigerator
My 685 freezer is fine, but the fridge is only getting upto 50
Check the compressor fan motor. Is it running?
Check the freezer and Fresh food fan motors. Arte they running?
Jan 04, 2010 | Sub-Zero 685/S Stainless Steel Side by...
Freezer no longer freezing and refrigerator is not cold enough either.
  1. check if the evaporator fan motor is running (inside the freezer)
  2. Same for the condenser fan motor on the bottom in the back of the fridge
  3. Clean condenser coils underneath or in the back of the fridge
  4. if there is a frost on the back wall in freezer - you've got the defrost problem, check defrost heater, defrost bimetal thermostat, and defrost timer
Oct 14, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung model rs2577sl. fridge side not working
5 reasons for fridge and/or freezer getting warm: 1- the evaporator coils are icing up and won?t let air circulate. 2- the evaporator fan is not working to circulate air. 3- there is no refrigerant in the system. 4- no power to fridge or compressor. 5- the condenser coils have no air circulation check under the fridge behind the vent. if it is too dusty or the fan isn?t working, it is not getting enough airflow to cool down. replace fan and/or vacuum out the dust. if there is no power to the fridge, the light will be off. if the compressor is not running, there is a defrost timer that cuts the power temporarily to the compressor to melt ice on the coils. it?s located under the fridge behind the bottom vent. If the timer is off and the compressor is not going, the compressor or the main board is bad and needs replacing. there is also a temperature sensor on the evaporator coils that tells the defrost coil to turn on and when to turn off. if the defrost timer is on but the coil is not heating up, replace the sensor. if it still won?t heat up, it?s the timer or the coil. the easiest way to tell if there is no refrigerant- the freezer wall is warm and the compressor is loud. if there is no refrigerant, it may be more cost effective to replace the fridge. if you feel no air coming from the freezer vent, the fan needs replacing. If you feel air moving in the freezer but not the fridge, the channel from freezer to fridge is blocked. if the freezer has air and the rear freezer wall has frost on it, the evaporator coils are iced up and need defrosting. causes: 1. low refrigerant 2. no fan 3. too much humid air in fridge/freezer due to door open or bad door seals 4. the condensate drain tube is clogged if the seal around the door is ripped or not completely sealing, or there is condensation at the bottom or the walls of the fridge, replace the seal(s). no air, no fan. Replace if the refrigerant is low, it just needs a top off. but you need to be certified by the epa to move refrigerant, so get a professional. defrost solutions: unplug the fridge. remove the wall of the freezer that is frosted/icing up. use a hair dryer to melt the ice. do not get too close. you will see a drain under the evaporator coil. make sure it is not blocked. the water should run freely to a condensate pan under the fridge that evaporates the condensation with the hot line from the compressor. once the coil is free of ice, frost, and water, replace the panel and repair any of the problems that caused the icing up. plug the fridge in and turn it on. If it frosts up within a week, there is still an issue that not been taken care of.
Aug 25, 2009 | Samsung Refrigerators
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Loud noise from the freezer side
Sep 20, 2008 | Samsung RS2630SH Side by Side Refrigerator
Samsung RS2630SH Side by Side Refrigerator Logo
186 people viewed this question
Top Samsung Refrigerators Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
